MF-235 Perkins Diesel Timing Cover
   / MF-235 Perkins Diesel Timing Cover #1
hendu7823
My timing cover is leaking oil from the top portion of it, I am going to have to change it and am curious if the cam or crank gear have to come out of off to change the gasket. I know it is going to be a pain but does anyone have some advice?
   / MF-235 Perkins Diesel Timing Cover #2
G'day and welcome:thumbsup:. Can you see if it is coming from the front cover or the plate that bolts to the block? If it is the front cover then all the crank/cam/timing gears remain insitu if it is from the rear plate then all the gears bar the crank and inj pump gear have to come off and the engine retimed. To pull just the front cover the harmonic balancer that drives the belts has to come off.
Jon
   / MF-235 Perkins Diesel Timing Cover #3
Hey there ,this is holt50 , about the 235 thats leaking oil out the cover ,you might just need to tighten up the bolts ,I have a 245 which is basicly the same tractor and Ihad to tighten them up a little,there is several of them Thanks
It is from behind the timing cover, between the cover and the block. Not looking good from what ya'll are saying.
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A52709)
2019 KOMATSU...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
