MF 240 the ones with the shut-off solinoid on the pump
   / MF 240 the ones with the shut-off solinoid on the pump #11
I have that type solenoid on my skid steer injection pump. If the wire connects with a spade plug the spade plug connection can get loose over time.
If the wire is near or being moved when you throttle up fast it would miss. If your solenoid wire screws on to your solenoid connection should be good.
I had trouble finding the cause of that issue. Its probably a long shot.
   / MF 240 the ones with the shut-off solinoid on the pump #12
since there is no black smoke when this happens, it's probably running lean upon acceleration!..
Client still using the tractor and will let me know when its avalible to me
   / MF 240 the ones with the shut-off solinoid on the pump #14
I have a MF 240 that runs and work great , but when I throttle down to idle and then jusks the throttle to full revs it starts to spatter like a petrol engine with a carburator that gets flooded .
If I take the revs up slow it runnes fine .
Help to diagnose ?
There may be a second piece with another wire that goes to the pump. It's a wax motor that adjusts your timing.
There is a second temperature sensor with two tabs.
This temp sensor may be defective or the wax motor may be defective. Most likely the wax motor. Pumpguysc is familiar with this stuff as well. Post a picture of your pump if you can.
Hi
What do you meen by "wax motor"?
   / MF 240 the ones with the shut-off solinoid on the pump #16
The #'s off the pump nameplate is required.
I would start w/ the air system 1st.. Take the air cleaner out of it & see if it still does it..
Is this a gravity fed fuel system or does it have a supply pump on it.??
When were the filters changed last?? if u dont know, change'm..
   / MF 240 the ones with the shut-off solinoid on the pump #17
I would follow pumpguysc's suggestions.
I don't think a wax motor is used on this tractor.
A wax motor is:
A wax motor is a linear actuator device that converts thermal energy into mechanical energy by exploiting the phase-change behaviour of waxes during melting, Expansion and contraction. Wax typically expands in volume by 5% to 20%
I need to get to the tractor to take a pic of the plate on the pump.
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
2015 DODGE RAM...
2022 JLG R3246 ELECTRIC SCISSOR LIFT (A51247)
2022 JLG R3246...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
