Mf 30 injector pump rebuild
   / Mf 30 injector pump rebuild #1
georgia088
Thomaston, Georgia
Mf 30?
Hey. I have an injector pump on a mf30 industrial that is leaking severely. Even when the motor is not running. I am looking for info on rebuilding it and where to find a kit. It has an AD 203 Perkins engine. The numbers on the pump are 3240F938. It is a CAV pump.
Thanks!
   / Mf 30 injector pump rebuild #2
Thanks!
This is pretty common for Perkins and CAV Pumps. They are nice in that they have very little moving parts, and are probably one of the easiest pumps that I know of to rebuild, but they have a lot of sealing surfaces to get that.
You can get rebuild kits for the CAV pumps readily, and not for much money if you chose to rebuild it yourself.
If you got 45 minutes, there is a guy that rebuilt a CAV pump for a 4.108 diesel Engine, and showed how it was done from start to finish. If I was you, I would watch that, and make a determination if you want to tackle the problem or not. A 45 minute youtube video might save you a lot of money on having it done in a shop.
It is your call, but 45 minutes doing something for free (watching youtube), would be worth it to me.
   / Mf 30 injector pump rebuild #3
Where is the pump leaking? Sometimes it is a easy gasket job, other times it is a little more complex. There is a forum member thepumpguysc who does diesel fuel system work for a living. Perhaps he could jump in and give some advise. I had to reseal the one on my Perkins, it was an easy job, but I was lucky.
I can not find a kit that is for my pump specifically. Are they all pretty generic and include all the needed parts for most all CAV pumps?
Its hard to tell, but it looks to me like its coming from several places....not good.
Would this kit be compatible with mine?
https://www.amazon.com/7135-110-Injector-Repair-Gasket-Ferguson/dp/B077ZRCRGZ
This video?
CAV Injection pump full strip down to re seal and stop fuel leaks - YouTube
Thanks for all the help. I may try and conquer this myself.
   / Mf 30 injector pump rebuild #7
:laughing:That video is a Bundy Bear video.
The pumpguysc loves those videos since they result in people screwing up their pumps which makes business for pump guy to fix the mess!! :laughing:
Do yourself a favor and click the link to pumpguys profile and send him an e-mail or PM.
   / Mf 30 injector pump rebuild #9
So, would this kit be compatible with my pump?
https://www.amazon.com/7135-110-Inje.../dp/B077ZRCRGZ
Thanks!
I am not sure if that will fit your pump or not, but that was the video I was talking about.
It was interesting/not so interesting when I went to Diesel Tech School because my first teacher, an old duffer, told us at no time, in any way, should we ever touch a injection pump, but to send it out and have it rebuilt.
But that year he had a heart attack and died, so we got a new teacher. And he was younger, and of a different mind-set. He was not afraid of injection pumps because he understood how they worked, and I was a second year student then, so he had use second year students dig into them.
Your pump is just leaking fuel. It is not rocket science...it is just an injection pump, and as I said a CAV pump is probably one of the simplest to rebuild.
But this is also the internet, for every person that will tell you, it can be done yourself, there will be twenty who tell you can't. But I propose; what is the worst that could happen? If it is easy, and you fix it yourself, you fixed it for cheap. If you can't, you send it in to be rebuilt. You are not out anything...
   / Mf 30 injector pump rebuild #10
OR.. the engine could run away.. dont forget about THAT ONE..
Yes the 7135-110 is the kit you'll need.. & a slew of "other" parts, as long as u have it apart..
I charge extra when a customer "helps".. cuz theres NO TELLIN what they've done..
It takes extra time & care trying to figure it out.. which = more $..
I had 1 fella who bought all sorts of parts they sell as a kit, online.. & not 1 of'm were for his pump..
Good thing, cuz he didnt need any of'm.. lol
2013 Ford F-150 Pickup Truck (A55788)
2013 Ford F-150...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
