MF 3600 Series
   / MF 3600 Series #11
I bought a used 2006 cab with powershuttle, 260 hours, this summer. I had a powershuttle solenoid failure last month. Easy to diagnose with the shop manual, and a $100 part. Other than that, it has performed well. I've hayed with it, and it was remarkably powerful and fuel-efficient with a baler and wagon in tow. I'm liking that Sisu engine. It's not that heavy, and is maxed out running a baler with full wagon on hills. However, it's light enough for yard work too. I read of some issues, and was hesitant to buy it since it had been discontinued, but the price was right. I looked at a lightly used 5445, but the price difference will be at least $20k. I think I'll hold tight for now.
   / MF 3600 Series #12
That is great to hear!! Please keep us posted.
   / MF 3600 Series #13
Update: over 700 hours on the 3635, used for full-bore field production. I'm currently pulling a 4-bottom plow, 12-foot discs, haybine, and baler with a 18' wagon. Tough little tractor, and no issues other than a blinking shuttle warning light a few times. I shut down and restart and it goes away. Other than that, it's been flawless.
   / MF 3600 Series #14
Can you explain how you diagnosed the problem and what the part was . Our 3635 will not go into gear just had it shipped out a month ago from the States
Do not find our manual that helpful. Is the shop manual different .
What is required to use the on board diagnostics , there is a cable to connect to a computer next to the fuses.
   / MF 3600 Series #15
I have the shop manual, with all of the codes. If you give me your fault code I'll tell you what the problem is.
   / MF 3600 Series #16
Unfortunately there is no fault code ,there was nothing showing on the dashboard as a code. the electronic unit has been sent to New Zealand for testing.
We are trying to figure out if it is the clutch or the solenoid. Can you give us the details of how you fixed your problem. Our manual does not have codes .
   / MF 3600 Series #17
WE have also contacted Witmers -Salem, OH 44460, the dealer it was brought from. they have been unable to help, still waiting for them to get back with a reply, they have sent the request to AGCO , been several months now and no answer.
Do you know of a dealer who has fixed this problem in the US. I could contact them for help.
   / MF 3600 Series #18
What is your unit doing? Will it just not move or not actually go into gear?
   / MF 3600 Series #19
It will not move as we cannot get it into any gear.Hydraulics work OK, front-end loader works fine.
Previously there has been problems with the oil filters getting blocked, cardboard like fibres which appear to come from the clutch disc. I have heard reports that the clutch system is not the best for front-end loader work, as every time the clutch is used oil no longer gets sent to the clutch discs and the disc start shredding.
Any info you have will be appreciated.
   / MF 3600 Series #20
Jarrah,
It has been a long time since this post was put up. I also have an MF3635 with transmission problems. Were ever able to get yours resolved?
2003 INTERNATIONAL 4300 BOX TRUCK (A51219)
2003 INTERNATIONAL...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
2015 DODGE RAM...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
