MF 3650 won't crank
   / MF 3650 won't crank #1
Calvinotte
Fredericksburg, Tx.
Massey Ferguson 3650
Call me a gentleman farmer. Not much mechanical experience. I came in from bailing, had the pto running with baler attached. Thought the tractor was in neutral and I pop the clutch and of course the tractor jumped and died. Now it won't crank or even try to crank. What could be the problem, what can I check, what can I do. The batteries are good, I even jumped them and reading a little over 13 volts.
   / MF 3650 won't crank #2
Please don't take this the wrong way, only intended to help. Is the PTO switch off? Is the tractor in neutral?
Yes, PTO switch is off and tractor is in neutral clutch pressed all way down.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
UNUSED HOSTAGE AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED HOSTAGE...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
UNUSED JCT HYD POST/TREE PULLER (A58376)
UNUSED JCT HYD...
