mf 4345 speed sensor question
   / mf 4345 speed sensor question #1
Hersheyfarm
Veteran Member
NE ky
after about a hour of use the speedometer stops working and it peeps/flashes code for it. its running me nuts. do these things go bad? i'm pretty sure its the one on top of back right axle, can anyone confirm this.
   / mf 4345 speed sensor question #2
I can't confirm for you which one it is, but they do go bad. I had to replace the tach speed sensor on my 4200 series last winter, it "sensed" off of a gear on they hydraulic pump. This type of sensor is getting very common on heavy trucks and tractors both.
Well, i aint priced it but I am just going to get one tomorrow. They seem like the cam sensor on the ford powerstroke that would crap out for no reason.
   / mf 4345 speed sensor question #4
Pretty much the same deal. The only problem I had changing mine out was getting the electrical connector apart without damaging it. Of course the connector was where you could "almost" reach it.
2014 Ram 3500 4x4 Crew Cab Reading Service Truck (A44571)
2014 Ram 3500 4x4...
Vermeer Navigator Directional Drill and Trailer (A44391)
Vermeer Navigator...
2001 Ford F-650 Altec TA40 Bucket Truck (A44571)
2001 Ford F-650...
2017 Yale GLC050VX 3,500 lb LPG Forklift  Powershift, Aux Hydraulics (A46877)
2017 Yale GLC050VX...
1998 KBH Fertilizer Tender Auger Trailer -30 FT (A46877)
1998 KBH...
Continental BeltonTowable Sprayer (A45336)
Continental...
