MF 500-406 industrial loader followed me home.
   / MF 500-406 industrial loader followed me home. #1
JANDG
Needed this like hole in head,but here it is.I suspect it is a 1958-59 & built in Kansas. The ID plate saysthe following. I can find anything on this tractor on the net. He gotme for 1400.00 & might have payed to much but couldn't resist.Thing is built dozer like. Much bigger than I thought once I got drove it home in 5th gear..*s* looks to be provisions for PTO that are bolt plated off on back, has very large remotes. everything works & runs good. The shuttleshift takes getting used to & jerky for me yet. The loader is stout & strange design. This would run over my little JD like a bug. Anyone ever see this model..? or know were info would be on it.?
Massey-Ferguson
Industrial Division
Wichita, Kansas.
Model 500-406
serial# 1643
   / MF 500-406 industrial loader followed me home. #2
Owner mention backhoe mounted on it, but he didn't own it very long. He took it on trade & he rebuilds dozers & such for a hobby. I can see 1958-61, but 68-73 seems not right. The id tag also has 1009 S. West Street Wichita Kansas on it. I suspect since they moved the industrial dividion to Detroit in 61 I think I read, this would date it from 58-61 if true. MF bought some company in in 57-58 in Kansas & turned that into there Industrial Division & then moved it to Detroit shortly after that. I will take pictures of the front & front axle & post them Friday.
Thanks Joe
I found an ID plate on frame yesterday.It says...
Massey-Ferguson Inc.
Racine, Wisconsin USA
Model# nothing is stamped or written here.
Serial# 653 000027
Also I found these #'s on engine.
G 16 V - on the block
E400A600 also on block
E223E 600 on manafold
E400A602 on top of head
large 2 AM also on top of head
Carb say "Marvel" something? on it
Also a 1/2" thich steel cross member has MHF Canada w/ 767607M1
Loader arms also has additional #675-2 & 1400 337 M1
I suspect machine has close kin to MF 356 industrial tractor shovel @ 10,700lbs. I could be wrong but they sure have alot in common. Trans, loader, size & shape. I still don't have a clue what it really is. looks like #27 built though.
Joe
   / MF 500-406 industrial loader followed me home. #5
I think its awesome looking. I bet it does move some dirt around. No idea the horse power huh?
I suspect around 60hp.I am researching this unit very hard. Definately built @ Racine, Wisconsin plant & suspect 57-58. It does have parts on it from the MHF Canadian plant also. I see parts so far from 3 MHF & MF plants. I have decided to keep it. The fact that it starts at turn of key stone cold & doesn't smoke & everything else working has me in. Allready started wire wheeling & getting ready to paint rusted & open spots,nothing fancy & just good industrial yellow paint to slow the rust down. Sure wish I could find an old picture of this unit, so I could compare. Might not be any left as I suspect not many were built for some reason. I think the transistion period in 57-58 has something to do with it. I will be attacking a stump or 2 with it in 2 months or so.
Joe
Positive ID has been made on the engine by Jerry @ Monte's Equipment.
It is a E223 w/ 3 & 13/16" bore & is a sleeved motor. @ 1600RPM produced 60.5 hp. Some Massey 85 models had this motor.Now on to the tractor ID itself.
Joe Parcher
   / MF 500-406 industrial loader followed me home. #8
Cool. Keep us posted. I am curious. If it were mine I would do just as your doing, protect it from further rust and I would use it around the place. If ya beat it up a little its no big deal. I think its cool looking.
   / MF 500-406 industrial loader followed me home. #9
I have a big beast like this, the serial number was found on the dash under steering wheel... Have not been able to find model, but my serial # 9A 290074 with 11L - 16SL front, 18.4 X 26 on rear... The bucket is 88" wide, tractor & Loader both industrial yellow, also has solid front axle, ...
Need to order parts and manuals, but have no clue what this monster is. It has 4 cyl diesel and looks to be in the 60 HP range...
When it rained today, I could see MF in black letters and the number 500 on the loader arms, please reply if you can help.... Email jjamit99@aol.com
Thanks
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle Crane Truck (A55973)
2013 Peterbilt 367...
EZ loader trailer (A56857)
EZ loader trailer...
1000000 (A47477)
1000000 (A47477)
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
