MF 5465. What is this warning light?
   / MF 5465. What is this warning light? #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
This light comes on usually after running the tractor a couple minutes. Also a red triangle light illuminates.
   / MF 5465. What is this warning light? #2
Low on transmission pressure or low on transmission oil?
   / MF 5465. What is this warning light? #3
Has the steering filter been changed lately? That will usually trigger that light. It's the filter inside the cast spin off housing on the right hand side. There is a temp switch that'll keep it off before the oil heats up. What year and transmission do you have? There could be other things but that's where I would start.
Year...???? Dyna 4 tranny. Yesterday it gave a code 23. Not sure if it's related at all. I noticed the warning dash light comes on after 10-15 minutes.
Cast spin off housing? Are you talking about on the right side under cab, behind tire. Looks like 5" diameter and maybe 9" long.
   / MF 5465. What is this warning light? #5
That's the filter. Year,serial #, or what tier engine. That would help. Start with that filter if you haven't yet.
Pretty sure it's 2008. Also had a code 23.
   / MF 5465. What is this warning light? #7
Hello I have the same problem with a MF 5455 year 2008 DYNA 4. Did you find any solution? I recently change the filters and transmission oil. Please give me any suggestions. Thanks.
Did you also change the canister filters as well? Somehow my notifications keep getting automatically put in my email spam. If you want, contact PM me directly.
   / MF 5465. What is this warning light? #9
Hello everybody! I have the same problem with these warning lights in a 5445 Dyna4.. Have you find any solution? sorry for my bad english..
No. My friend serviced his and it went out briefly. But he has been running every since, and it doesn't seem to have affected his. Are you experiencing any problems?
Kivel 42in Forks and Frame Skid Steer Attachment (A44571)
Kivel 42in Forks...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
CAT 345 Excavator (A44391)
CAT 345 Excavator...
1020 (A44391)
1020 (A44391)
2008 Toyota Camry LE Sedan (A44572)
2008 Toyota Camry...
2017 MINI Countryman Hatchback (A44572)
2017 MINI...
