MF 5465
   / MF 5465 #1
Dgross51
MF 5465
Will not start whether hot or cold, only with ether.. New injection pump and injectors. Fuel supply good right up to injectors. Compression is good. When turning over little or no smoke. Had same issue with old pump and injectors. Engine was then overhauled. 1106C 6cyl. Has Emc, with mechanical injectors.
   / MF 5465 #2
never personally dealt with it but isn't there pump or injector timing involved?
I may be way off base.
   / MF 5465 #3
Once you get it started with ether does it run OK ?
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
2008 Genie ManLift (A50322)
2008 Genie ManLift...
2008 PETERBILT 335DAY CAB (A51222)
2008 PETERBILT...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
