MF 5465
   / MF 5465 #1
Dgross51
MF 5465
Will not start whether hot or cold, only with ether.. New injection pump and injectors. Fuel supply good right up to injectors. Compression is good. When turning over little or no smoke. Had same issue with old pump and injectors. Engine was then overhauled. 1106C 6cyl. Has Emc, with mechanical injectors.
   / MF 5465 #2
never personally dealt with it but isn't there pump or injector timing involved?
I may be way off base.
   / MF 5465 #3
Once you get it started with ether does it run OK ?
CONTACT INFO (A53084)
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2019 Dodge Challenger Coupe (A55853)
2019 Dodge...
2019 JOHN DEERE 350G LC EXCAVATOR (A52707)
2019 JOHN DEERE...
2025 Ligchine Spiderscreed Concrete Screed (A55851)
2025 Ligchine...
