MF # 62 plow
   / MF # 62 plow #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
I gave this old 2 bottom plow a new home this weekend, it's far from new but should have a lot of use left in it. Most of what I'll be doing is a vegetable garden in the spring, and maybe turning some pastures for replanting in the future.
From what I can tell it's a 12-inch, I think the distance side to side between the landsides is the size?
The points were in better shape than I originally thought, I touched up one shin with some weld on Saturday. At least for now, it's going to get a couple coats of paint and maybe some more welding on worn areas then get tucked into bed for the winter.
Sean
   / MF # 62 plow
A bit more work done, the U-bolts holding the cross-beam were rusted solid. I had to cut the nuts off, then build up the U-bolts with weld and re-thread them.
The bottom corner of the mouldboards were worn to a knife-edge, I welded some 3/16 steel on the back and shaped it to match the original profile.
I think I'm going to do some more work on the coulters, one is seized tight. Maybe next weekend..
Sean
   / MF # 62 plow #3
Wow! You do good work! Congrats on the find.
   / MF # 62 plow
It's one of the fun things (for me at least) about old machinery and implements..
I like repairing things like this, most of them just need some time and a little patience. Any excuse to break out some tools brings a smile to my face.
With the amount of plowing I'll ever do, it should last for a hundred years more.. although if I have to turn some pastures it may get some serious work.
There's an Antique Engine and Tractor Society (Club?) very near where I live... I may have to drop in some day and see what's going on. The only trouble with that is space to keep all the "collectables" I know I'd end up searching out. They had a display at the local fair last weekend, I watched an old Deere running a shingle mill for a while.
Sean
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Brent 644 S/N B29820157 (A52128)
Brent 644 S/N...
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
UNUSED FUTURE MINI...
