MF 65 Injector pump no fuel to injectors
   / MF 65 Injector pump no fuel to injectors #11
Try cracking the injector nuts 1 at a time, starting with the one closest to the pump. Crank until fuel comes, then tighten and move onto the next one. Hope this helps.
hand pumped fuel comes out of the little bleeder screws close them crack the injector lines none comes out.
   / MF 65 Injector pump no fuel to injectors #12
Sunbird.. all your doing is bleeding the LOW pressure side of the pump.. Basically, from the tank to the inj. pump.
Your problem is in the HI pressure side of the pump.. either a stuck metering valve or stuck pumping plungers..
& U HAVE TO go inside the pump to repair..
IF this is beyond u, contact me by clicking on my screen name on the left side of the page..
I don't charge for estimates & wont give u back a bucket of bolts either..should u choose not to have it repaired.
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
3650 (A47477)
3650 (A47477)
MOORMAN'S APACHE CREEP / SELF FEEDER WAGON (A52708)
MOORMAN'S APACHE...
2011 Audi Sedan (A56859)
2011 Audi Sedan...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
