millsan1
- Joined
- Feb 10, 2015
- Messages
- 324
- Location
- Riegelsville, PA
- Tractor
- Mahindra 2538 Cab, Volvo ECR40D Excavator
can you run another pressure switch in parallel on that line that will turn on the well pump when you open a spigot? should not interfere with the house behind the check valve. set it for 5 or 10 psi lower than your house pressure to keep the check valve closed.
Probably could, but going to try moving the check valve back, as that is more straightforward.
