MikeyMonster
Hello
Ive a Massey Ferguson TEA28 (i think the 28 is the nz version of the more common 24 but im not sure). Anyhow it has low compression in cylinder 2.
90,50,90,90. I thought it might be a bad valve but it doesnt appear to be. Im wondering if anyone has any tips on working out if its the headgasket or the piston/rings?
Also can you replace the pistons on these by removing the oil pan and dropping the piston out from below?
Its a petrol by the way.
Ive never worked on a tractors or cars engine internally before although i can rebuild a two stroke outboard motor as easy as pie.
I appreciate any response
Mike
Mike
