Oil & Fuel MF65 too much oil psi!!!
   / MF65 too much oil psi!!! #11
something else, In your spare time? Have you looked closely at the oil filter adapter for a by-pass valve in it. Some autos have a pressure relief in the oil pump and in the filter base or adapter? I have had pegged oil pressure guages too in the past, but automotive type.. 2cents..
   / MF65 too much oil psi!!! #12
Those bypass valves usually work on differential pressure across the filter media. They operate at a low value [like maybe 5psi] so as to allow oil flow in an engine with clogged filter or cold oil. His symptoms would not be caused by a filter bypass malfunction.
larry
   / MF65 too much oil psi!!! #13
True enough, it would not effect him...high oil flow is bypassed at 4 psi.according to my manual from the 70's....did not understand the oil pump output being so high? Common on this model?
2014 John Deere 4940 Sprayer (A53485)
2014 John Deere...
2012 Ford Fusion Sedan (A55853)
2012 Ford Fusion...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A57024)
2018 John Deere...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
