WilliamBos
Super Member
- Joined
- May 1, 2004
- Messages
- 5,278
- Location
- Innisfil, Ontario, Canada
- Tractor
- MF 1635 12x12 Powershuttle
I use Permatran, MF calls for it.
I spoke to the tech at our dealer, he said what you did. Since i have plenty left over from trans services, we use it. We still have some incase we need a top up.They do not always list it in the manual, but MF also recommends gear oil, in axles. My manual says "Permatran 3 -or- SAE 80 GL-4". Both are acceptable. If you contact them, they will confirm that.
There is no wet breaks in your front end DeereMann. I would GUESS there is bevel gears if the front axle does not have visible u-joints. I would second your gear oil selection.
Thanks spruce Deere.
I think yours is another vote for GL-5 gear oil, as there are no wet clutches or brakes. Just as long as there aren't any non-ferrous alloy metals in there, either. GL-5 gear oil has an aggressive EP package including sulfur, chlorine, & phosphorous that will eat up non-ferrous metals.
There has to be a bevel gear in there somewhere - the front propellor shaft is perpendicular to the drive axle shaft, then a drop-gear to the planetary gear sets in the wheel hubs. A pretty expensive setup!
