Mowing Mid Mount (Belly) Mower with Gear Shift Transmission
   / Mid Mount (Belly) Mower with Gear Shift Transmission
Sorry, I'm confused. So get a belly mower for your 790 and you get what you want, no? A gearshift and a belly mower.
My Deer store says they don't have a mower to fit that model plus mine doesn't have mid mount pto so it would be more costly to adapt.....even if I could find a mower deck to fit it.....which I haven't and I don't know enough about the older models and neither does my dealership to know what would fit it. I just haven't found anything in the used market.....but I'll admit I've been jumping around struggling!
I've been trying to buy a tractor with a 72" mower already installed in a gear shift model. But I'd go with HST in a heartbeat now that I know that some HST models have independent braking ability.....thanks jthibodeau89 !!!
   / Mid Mount (Belly) Mower with Gear Shift Transmission #12
I've never owned a HST so I didn't know they built them with individual brakes on the left like you said. I've talked to several dealers and no mention of this in a belly mower application.....they apparently only want to sell me new and the 3r series doesn't offer that! Do you have a belly mower on yours? How high is the maximum you can you raise the deck off the ground.....if you know?
I have a 72" belly mower that came with it, but have never mounted it. I would guess 6"-7" at the highest lift. I would have to mount it to see. I do my mowing with a 3pt JD 25A flail mower.
One warning on the mid 90s 4300, they roll sod on tight turns. There was a TSB if you complained and JD replaced the front axle. They got the turning ratio wrong. I think my outboard tire swings 70 degrees. I also run R1 Ag tires due to our hills. The R4 are too narrow track for my property. Already had a few down hill slides. No fun.....
   / Mid Mount (Belly) Mower with Gear Shift Transmission #13
I'm not sure specifically with the 790, but I know on one of the Kubotas I own that the mid mount mower is driven off a front mount pto, which is something like a front mount snow blower would drive. It just has a drive shaft off the front PTO back to the belly mower.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
