Mowing Mid Mount Mower Belt
/ Mid Mount Mower Belt #1
Skip G
Cheshire, Oregon
Kubota BX2200
Hi all
Have a 60" MMM for my BX2200. Removed and serviced it for winter storage.
According to the manual, the belt should be loosened for winter storage.
Is this necessary ?
Another dumb question...
What's the best way to remove it?
I tried for a few minutes, but couldn't seem to get the idler pulley to move to get the slack necessary.
/ Mid Mount Mower Belt #2
Look for that magic spring that puts tension on the idler pully
Jim
Thanks, yes saw the spring. I guess just remove one end ?
/ Mid Mount Mower Belt #4
Remember this! That spring has lots of tension on it and make a drawing before you take it apart.
Jim
/ Mid Mount Mower Belt #5
What I do is pull up on the belt on the pully as I am slowly turn it and walk it off the pully. I then repeat the same process in the spring. The spring has a lot of tension and can do some damage, so BE CAREFULL, wear gloves and and safety glasses. Same belt since 2002!:eek:
/ Mid Mount Mower Belt #6
Guess I need to do something--I haven't taken my MMM belt off since 2003 when it was new, or loosened the belt............
ron
/ Mid Mount Mower Belt #7
I did not remove my belt last year but was thinking about it this year. I'm sure Kubota is really proud of those belts.
/ Mid Mount Mower Belt #9
Just took my deck off tonight for the first time, in prep for winter. Haven't taken the belt off but plan to ease the tension on it. I wish the deck on my old Toro came off as easy as the Kubota.
/ Mid Mount Mower Belt #10
I can't remember *exactly* how I do it, but I found I could use some part on the deck as a fulcrum and pry against the pulley arm to unload the belt pretty easy. Have slipped it on/off the last couple of winters no problem. We're still mowing down here...
Russell in Texas
I've had my deck off once before.
It's easier to take off than put on. That shaft is a son of a gun to line up and get back on. I wonder if there are any tricks to getting it to go back together easier.
/ Mid Mount Mower Belt #12
Id also add "tie a piece of carpet or a towel around your head for the first time the lockjaws or vice grips slip off the spring as you in the forehead as you are trying to pull the end of the spring into the little hole.
/ Mid Mount Mower Belt #13
The easiest way to reinstall the MMM is to hookup the PTO shaft 1st then mount the MMM to the tractor . This way you can move the MMM around inorder to get the most room possible.
Make sure you lock the collar back on the shaft and it will slide on the pto much easier.
It gets much easier with practice :D
Volfandt
/ Mid Mount Mower Belt #14
I found that a large screwdriver prying from between the idler pulley and spring mount supplied enough leverage to remove the belt- reinstalling it will be a slightly different process but I don't have to worry about that until Spring!!
I, too, did not loosen my belt for the first 3 years and am still on the original, but this is only because I did buy a spare and have it handy!!
At 500 hours I also just did my first gear oil change in the mower gearbox that was "mandatory" at 50 hours!!!
/ Mid Mount Mower Belt #15
I learned the trick for connecting that heavy spring from someone here is to use a rope to pull it. No way was I able to connect just using arms... needed to really get some pulling power using legs.
mark
/ Mid Mount Mower Belt #16
Don't know if it will work the same for a 60" but here's a couple of pictures of how I do it on my 54" deck.
This is such a great site to get answers.
I'm glad I asked the question and wasn't the only one having trouble getting that belt off.
/ Mid Mount Mower Belt #18
I've kept my belt on the whole time. It doesn't seem to be worn or slipping. Has anyone left it on and had it wear out because they did that?
I realize this belt is like $100 so it is a concern. I don't have a money tree or anything like that.
/ Mid Mount Mower Belt #20
No money tree here either, and mine has been on since new July '01 and I never take it loose either, maybe it would just last forever if I did.
UNUSED FUTURE EXCAVATOR COUPLER (A60432)
UNUSED FUTURE...
Kubota Snow plow with subframe
Kubota Snow plow...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
