Midwest Equipment and JD I-Match - work together?
   / Midwest Equipment and JD I-Match - work together? #1
Boiler74
Indiana (Purdue country)
John Deere 4710
Midwest Equipment says their implements are Catagory 1 quick hitch compatible. Does anybody know if that means all I need to do is add bushings to an implement and my I-Match will hook right up to it? Or will it be a little more involved than that. A guy about an hour away from me has a landscape rake for sale, and I don't want to drive up there only to find out it won't work with the I-Match. Figured a few of you out there have this combo and can answer this pretty easily. Appreciate any help that you can give.
Thanks,
Josh
   / Midwest Equipment and JD I-Match - work together? #2
It should. Looks like an other quick hitch I've ever seen.
   / Midwest Equipment and JD I-Match - work together? #3
Josh: You will find that the lower Cat 3 mounts will line up fine with ther JD Quick Hitch. I believe that the space between the Lowers is 26 1/4". The upper bracket is where I found my problems. The JD top hitch is fixed in position and the implement may require a bit of work to make it fit. They also sell an extension for the top hook.
Northern Tool and TSC also sell a quick hitch that has an adjustable top hook and the extension came with it.
If you have the JD I would make the drive and take it with me and see if it fits the implement or requires some adjustment to make it fit.
   / Midwest Equipment and JD I-Match - work together? #4
I know that the JD Quick Hitch conforms to the ASAE standards for quick hitches, and Jim McC of Midwest Equipment has stated many times on this forum that his designs also conform to the standard. Thus I think the probability is high that the I-Match Coupler will fit directly with Midwest Equipment Implements.
If in doubt, just take the I-Match coupler and a set of sleeves with you to examine the implement in question--no need to take the whole tractor if that is a problem.
I would think it worthwhile to drive an hour to make this check with a high probability that everything will fit fine.
JackIL
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
CAT 973 (A47384)
CAT 973 (A47384)
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
