Mig welding gas?
   / Mig welding gas? #11
"what again are good reasons to use 90/10?"
For you Mark, nuthin' -
1 - costs more, cause there's more argon.
2 - Say goodbye to autoset
3 - Forget your door chart
4 - No OOP in non-pulse spray
5 - The earlier mm211's might ALMOST have the balls to get into spray mode, I've heard of exactly ONE user that CLAIMS he did :rolleyes:
Other than those few little things, no prob :laughing: ... Steve
   / Mig welding gas? #12
I use C25 but I think my next tank will be CO2. I want to eventually buy an Argon tank and mix my own. That way if I want C25 I just mix it that way. If I want C10 I just mix it that way. In MIG class we did spray on thicker than 3/16 using C10. But we were using Lincoln 350 MIG machines. The spray sure is pretty. The Lincoln 350 MIG had pulse but we did not cover it in class.
   / Mig welding gas? #13
What I thought. Thx.
   / Mig welding gas?
Thanks everyone for all the input, I have decided on the c25 gas for most of my mig welding, I guess if I use flux core the machine polarity need to be changed, I have some outside welding to do on a trailer, non structural.
Looks like flux core or stick welding outside
Once again thanks everybody for your input
   / Mig welding gas? #15
Swapping to flux core isn't necessary for outside work UNLESS there's a fairly noticeable breeze - I've even hung a couple tarps up (not TOO close) for a wind break. I usually up the flow to maybe 25 cfh if I can feel ANY breeze on site.
It CAN be kind of a PITA to move a cart and tank, I have two ways around that;
1 - A 30 foot spool gun for the bigger welder, or
2 - My little MM211 is on a "go anywhere" cart
https://www.tractorbynet.com/forums/build-yourself/387658-container-weld-shop-build-20.html
Which can also double as a tarp anchor.
Disclaimer - I understand that i'm not "normal", you may find it easier to switch :D ... Steve
   / Mig welding gas? #16
Normal yes. I'd do just about anything including stick to not have to run Gasless cored wire.
   / Mig welding gas? #17
Me too, especially since I added this to the herd a few years ago
Power i-TIG 2T - TIG Welders | Everlast Generators
Even a SHORT set of leads weighs more than that little guy, has hot start, arc force, DC tig, and 9 memory slots for either stick OR tig faves... Steve
   / Mig welding gas? #18
100% argon is going to leave you with a ropey weld on MIG. I wouldn't recommend it. C25 for that machine on short circuit.
   / Mig welding gas? #19
I use 90/10. I have C02, but find myself using 90/10 for even 3/8” plate because the welds are ribbon smooth and splatter free.
   / Mig welding gas? #20
You might check this out but I’m sure I’ve read that straight CO2 gives better penetration. I use 75/25 but I’m no expert.
Trump 2028 Decorative Sign (A55758)
Trump 2028...
2013 Ford Escape SUV (A55758)
2013 Ford Escape...
2008 Chevrolet C7500 Truck, VIN # 1GBM7C1G78F413329 (A54865)
2008 Chevrolet...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
(4) UNUSED 12-16.5 Tires on Bobcat Wheels (A47477)
(4) UNUSED 12-16.5...
