Miller maxstar 140 str
   / Miller maxstar 140 str #1
GreatWhitehunter
Eastern CT
JD 110 TLB
I'm in the market for a small portable stick welder and ran across a lightly used max star 140 str. This is mostly for around the house stuff. The seller claims he welds 1/2 without issue. I have no interest in TIG so I'll just be making stick repairs to implements etc. is this a good welder for my intended purposes?
Matt
   / Miller maxstar 140 str #2
One of the Maxstars won't run 6010. Cant remember which one tho:eek:. If you want to run 6010 may want to check into which one will not run it.
   / Miller maxstar 140 str #3
My Maxstar 150STL won't run 6010, but that may just be me.
Terry
   / Miller maxstar 140 str #5
It's not just you - the maxstar 150 was designed that way - but runs 6011 just fine.
Thanks, Dave. Good to know. For over 40 years the only welder I ever used on the farm was an AC buzz box with 6011 and 6013.
...so I'm kind of new to everything else.
Terry
For the farm welding I tend to do I generally use 7018. I'm a novice at welding and most of my work is repairs. I've run a 150 that I borrowed from work and it performed quite well at those tasks.
Matt
   / Miller maxstar 140 str #7
I had trouble running 6010 with my maxstar 150. Ended up with a ESAB 161 for small work and really like it.
   / Miller maxstar 140 str #8
OMG. Does that make me the only one who didn't switch to an ESAB 161????!!
Terry
   / Miller maxstar 140 str #9
Terry
....did I mention that my maxstar is no longer in the shop and an ESAB 161 took it's place? :dance1:
Although I only did it because I had the stick only miller, and replaced it with the stick/tig ESAB.
With 7018 they welded identical.
   / Miller maxstar 140 str #10
Terry
Killbros 260 Seed Conveyor (A57024)
Killbros 260 Seed...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
