milwaukee battery 1/2" impact question
   / milwaukee battery 1/2" impact question #43
Hum - you are using a impact wrench to torque the lug nuts on your cars wheels ?
Not a good practice.
I just did the spring tire change over on 3 vehicles using my Milwaukee M18 1/2" removing the lugs and installing them using a torque stick it didn't even take the battery down enough to put it on the charger.
Of course I also use never sieze on the wheel studs and the hubs and rims.
   / milwaukee battery 1/2" impact question #47
It is said not to use a torque stick, or at least rely on it- especially with a non pneumatic impact. One probably shouldn't ever rely on them I guess. That being said, I do the same sans the never seize. Then a walk around with the big T.
   / milwaukee battery 1/2" impact question #48
Because I do use lubricant I use a bit less then the recommended torque on my pickup 110# versus the called for 130# Iv'e verified the results with a torque wrench a few times and it has been quite good.
The last tire I've had come loose was back in the late 80's from a tire shop.
   / milwaukee battery 1/2" impact question #49
I don't own a torque wrench. I rotate all my vehicles tires/wheels. I use a pneumatic gun, no torque stick. I've never lost a tire/wheel. I use the "rat a tat tat tat" method. :)
   / milwaukee battery 1/2" impact question #50
You are playing with fire old man.
2020 DRAGON ESP...
2012 FREIGHTLINER M2 FLATBED (A58214)
2012 FREIGHTLINER...
2017 Toro Greensmaster 3150-Q Commercial Reel Mower (A56857)
2017 Toro...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
UNUSED CFG INDUSTRIAL H12R EXCAVATOR (A58375)
UNUSED CFG...
