Mini round bales
/ Mini round bales #1
bunyip
Elite Member
Flynn Victoria Australia
Kioti DK 5810 HST
Friends of ours are cutting hay and have made small round bales for us, they weigh 240kg which means I can move them around with the BX2370, going out today to pick up the bale spike for the bucket.
Happy horses, happy daughters.
Normal bales are about 600kg and I really don't want to buy a bigger tractor when the BX does everything I need except pick up big bales.
/ Mini round bales #2
I thought the mini rounds were under 100lbs?
Ibex TX31 Mini Round Baler with twine
bale Size (diameter x width) 20” x 28”
Bale Weight (lbs.) 30-60 lbs
/ Mini round bales #3
Here you go small round bales from one of the original round balers;
/ Mini round bales
I know nothing about baling and all I have seen are the big net wrapped balesor silage, the offer was made for the smaller net wrap and I took it, less work than the squares when it comes to storage and handling.
Consider myself educated after watching that video.
/ Mini round bales #5
That is one nice thing with the big round baler is the bales can be made to a desired size.
/ Mini round bales #6
If you are buying a spike that goes on the edge of the bucket you might be over loading your tractor according to Tractordata. The weight will be to far in front of your pins. If you want to use the FEL you need to get the spike that attaches directly to the FEL as a pin on or as a quick attach whichever you have on the tractor. Make sure you have a large enough ballast for the bale. A rear mounted spike would be a better option for your tractor.
/ Mini round bales #7
Exactly. My NH 450 Utility can make rounds anywhere from 2 feet in diameter up to 6 foot in diameter and wrap in net or twine with varying density (weight).
/ Mini round bales
I had no idea that balers were 'programmable' so to speak, and I didn't know that round balers could use twine.
Was watching a doco last night on trains in Japan, in the fields were what looked like the old wheatsheafs but they had a domed top, no idea what the crop was.
A quick google search shows it may have been rice but couldn't find any images with the dome, the rice as at the bottom and tied off at the other end, and I know less about rice harvesting that hay or grain crops.
/ Mini round bales #9
My Hew Holland is 100% computer controlled. Running it is like watching a video game. The screen tells me when the bale chamber is full, when it's wrapped with twine or net (whichever I chose) and when I need to expel the bale. I have 15 different twine patterns to chose from and I can run 3 different net widths too. I usually run 52" over the edge net, bales keep better and if I run twine, I use extend length twine balls, 25,000 feet each. Ain't cheap to buy either (baler).
Just sit in the tractor with the AC on and the FM listening to hillbilly music.:D It's business for me.
/ Mini round bales
I have seen balers for sale, could buy a small house for the same money, does it do silage too or is that another machine?
/ Mini round bales #11
No, mine is for dry hay only. Silage balers use different belts and the pickup is different. I sell 99% of what I run to a local rancher that feeds his bulls. Everything today is expensive in farm equipment.
/ Mini round bales #12
Our deere is a bit less complex but it can do dry or silage bales,
and either twine or net, we use mostly over the edge net probably 90% and twine on 10%.
/ Mini round bales #13
What is the difference between silage and hay? I'm just curious about the wording being used.
/ Mini round bales #14
Silage bales are not dry hay, it is baled at around 40% or higher moisture then the bales are wrapped to keep the air O2 out,
and allowed to cook up or ferment into silage. It makes for a more digestible feed and requires less drying time in the field.
Mid to late summer around here it is possible to start mowing around 10 AM after the plant sugars have risen and bale in the late afternoon.
Silage has to have the air excluded or instead of cooking up it will mold and rot.
IMG_20190523_153103865.jpg IMG_20190523_153122517.jpg IMG_20190523_153146379.jpg IMG_20190601_174134517_HDR.jpg
Also it allows us to harvest hay when the good weather window is to small to mow and dry it for dry bales.
We will also wrap some of our dry bales when we don't have enough covered storage.
Wrapped bales have to be handled carefully as if you puncture the wrap it will allow air to get to the bale and you just wasted a bunch of time and money.
Most wrapped bales are silage bales.
/ Mini round bales #15
The smell of cured silage reminds me of pipe tobacco. Never had the need here. Only dry hay or above 15%RM with acid applied. Don't bale cornstalks either. Too hard on me and the equipment.
Never been too enthused about JD balers. I prefer New Holland hay tools though I do own a JD mower conditioner as a backup for my NH disc machine.
Having said that, I don't care for Hew Holland tractors either. Too 'European' for me. I'll stick with my large frame Kubota's but not the new ones (Tier 4 final). Mine are 2002 and 2004 M9's. No emissions, just the way I prefer them to be.
Goosen Bale Chopper Hay Blower (A61166)
Goosen Bale...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A61165)
2002 International...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2011 Case IH Magnum 315 Tractor (A64047)
2011 Case IH...
Hercules Pesticide Applicator with Nozzle (A61568)
Hercules Pesticide...
2017 Chevrolet Express 3500 Passenger Van (A61568)
2017 Chevrolet...
