Missing 777
   / Missing 777 #501
LOL and when they do, they catch fire. But they were a bargain.
Yes, a real bargain. For what has been spent on this fleet of ancient antique underwater boats a nice new UP TO DATE version could be out and about.
Now we'll probably be paying for the disposal.
   / Missing 777 #503
The boat towing it.
That should get you within a couple of miles. With the cable for the receiver, it is hard to tell exactly where it is located, because it won't be straight down.
   / Missing 777 #504
What's the going odds that as they detract us for a few days/week with "We've detected pinging and are closing in"; shifts to "We need to bring in special sonar/ submersibles to look closer, that's going to take a while"; shifts to "Aw dang it!, the black box batteries must be dead, we can't find anything!" ? - 50/50?
   / Missing 777 #506
Dan,, just wondering how you came to have such expertise in all subs for all nations?
Not an expert at all but I read history books, funny that the Cold War is now History which is a good thing but it seems like yesterday...
I have been reading the US Naval Institute's Proceedings for over 30 years. Someone brought old copies of the magazine to the barber shop when I was a kid and I have been a subscriber ever since. The Proceedings is the professional magazine for the USN and USMC but mostly USN. For years I have read a couple of websites that cover military issues and one is very Navy based. The information is out there in public sources if one is interested. I am interested. :D:laughing: We do not watch much TV, in fact the TV has not been turned on since Sunday and likely will not get watched until Friday. Even if I am watching something, I usually read while watching. I read constantly which is a habit I picked up years ago in elementary school... :confused3:
The Chinese are spending some serious money to modernize their armed forces. They have a long way to go but they are willing to work long term to achieve their goals. Their subs stink. For now. They have problems with nuke reactors and I am sure other things as well. Their ships are better and they are deploying them farther from China and for longer periods of time. They are starting to build decent aircraft. Their biggest problem is building long lasting, reliable jet engines. The Russians can't do it and the Chinese are starting with stolen Russian technology. They certainly are after US and EU technology but so far they have not been able to build first class engines but eventually they will. The Chinese are building a large "Coast Guard" which actually are a few different agencies. They are using these "civilian" ships to harass regional governments and the USN over disputes in the South China Sea and up to Japan. It is a Cold War tactic the Russians used to some extent but the Chinese are really turning it up. It is bullying to the regional powers but effective yet it is really dangerous to be doing this to the Japanese and the US. It easily could get out of hand...
It looks a bit like the Cold War...
Later,
Dan
   / Missing 777 #507
From what I read, the boxes do not send out an continuous sound but a ping. Continuous sound would really drain a battery fast. The pings are being heard infrequently and at different levels. This could be because of bottom conditions, battery conditions and/or sea conditions.
It SOUNDS like, no pun intended, that there is a good enough fix that EVENTUALLY the plane would be found even if the batteries go dead. It just will take much longer to find the plane.
Later,
Dan
   / Missing 777 #508
You can pretty much bet that the ship towing it has a computer monitoring surface speed, direction, drag on the tow cable, length of line out, angle, etc... that puts it all into a calculator that spits out the exact location of the towed antenna to within a few feet of accuracy.
   / Missing 777 #509
one would hope so..
   / Missing 777 #510
Having done a bit of SCUBA I can tell you that underwater sound does not travel like airborne.
With airborne you simply turn from side to side and soon know the direction.
Not that way under water. Just ask any diver how he feels when he hears an outboard motor.
I dive deeper until I no longer hear it!
You do know if it is coming or going (fades or increases) but direction is impossible to determine.
Very much like the old aviation ADF system however whereby you flew in a straight line to determine if you are closer or farther and then return to determined 1/2 way or center, make a 90 deg turn and repeat to try to find where X marks the spot.
On that 2nd pass you also needed to fly from faded signal to strongest onto faded and then return to 1/2 way.
Problem with towing a 2 mile deep receiver on probably a 3 mile cable and a big ship that has no brakes means BIG turn and long time lapse.
In a plane that procedure is a mere 10-15 mins while a ship it possibly is measured in hours.
Count all the turns and add the turn radii lapsed time doing it at mere knots.
The modern advantage is that can all be done with GPS accuracy so as long as the locator transmits they will locate that beeper.
One problem that will affect accuracy will be underwater currents as at that depth there possibly could be a mile or 2 error with surface position.
Very similar with winds aloft when flying whereby difference at surface can be as far off as 90 deg and 30-40 mph at 40,000 ft.with all kinds of variances in between.
There is so much air travel that all that data is readily updated and easily available.
Not, however a whole lot of submarine travel to justify accurate data nor availability.
2019 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2019 Top Hat...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55301)
Case Wheels for...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
