Mitsubishi MT372 Stopped Pumping Fuel
   / Mitsubishi MT372 Stopped Pumping Fuel
OK, I won't be back out there for a week or so and I'll try to remove it when I get there. Thanks
   / Mitsubishi MT372 Stopped Pumping Fuel #12
I never saw where you bled the fuel system. The pump can not pump air. Start at the tank & open each bleeder screw enough to let air out, then close . There should be two on the fuel bowl & one on the injector pump. I get many calls for people trhat think they need an injector pump when all they need to do is bleed the system. If you do want to set it out by the road i do buy parts tractors.
   / Mitsubishi MT372 Stopped Pumping Fuel #13
Start by checking fuel level in tank. Make sure it flows freely by gravity - the filter is a good place to start. You could have crud in the tank. Bleed the fuel system per the manual - if you have one. If the pump is indeed bad it can probably be rebuilt. A local shop was able to rebuild injectors on my old Mitsubishi D2350. I'd go for the simple stuff before scrapping the tractor out. You'll get very little for the metal and likely have to pay for disposal of the fluids.
If you disconnect the 2 lignes of fuel
Before the injectors 2 the fuel lines must flow
About 8 inch If you rebuilt the pump
Remembrer If you remove the 4bolt
For the pump not to.loose the factory
Spacer for timing .leave it there While
Pump is rebuild
Denis
If not have thé pump rebuild and the 2 injector chez for rebuilt
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Danuser Digger F-8 (A52748)
Danuser Digger F-8...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
2006 International 9400i (A52748)
2006 International...
