Oil & Fuel Mitsubishi or Satoh ?
   / Mitsubishi or Satoh ? #21
Larry, thanx on any info by the way. Where found mine, it was equipped with a belly mower and I opted out of it to make a better deal as I have nothing really at all to cut plus have a rider anyway. I did ask the salesman about later on on a PTO driven 5' brush hog and he said no problem but will have to go a little slower than a bigger tractor but it would handle it easy. We have the good PTO with 2 speeds and CAT 1 3 pt. He mainly said make sure blades stay up to par. As far as you having the book, BIG +++, can you post up about all the fluids, where, how much and type? That would be a big help right off the bat. Thanx in advance. Maybe even start a SPECS Thread just on these as the info is so limited.
   / Mitsubishi or Satoh ? #22
Here is what I found in my instruction book Page 1 and 2 are the capacities and are duplicated. Page 3 is the types. And page 4 is the how to on the transmission and hydraulic oils. Hope this helps Ya'll.
  • Capacity and type for S-650.pdf
   / Mitsubishi or Satoh ? #23
Larry. You are the man!!!! Thanx so much for the info as I am sure it will help as I really have nothing,,,lol. Is there an ISBN (?) code on your book as to maybe lead me better in trying to find one to buy? I've seen a couple books is all but makes it hard to believe there is not more out there like every other kind of tractor on the planet. Not disappointed in buying the Satoh, just wish there was more info, oh well. I also read from a forum, maybe this one, where someone was gonna make a sticky and copy the whole book. Then someone chimed in and said its against copyright law. Me and a couple others have found this to be Not True as of 1989. Hint, Hint, just kidding but it would help. Your awesome for your trouble and help. Thanx again for this and any/all you may feel pertinent that we may need to know. Chuck~
   / Mitsubishi or Satoh ? #25
Thanx for the site info! What manual do you have that your getting the info from as that sounds like the one I need to get?
   / Mitsubishi or Satoh ? #26
Mine is the instruction book and has 62 pages. Of all the listed manuals I think the operator manual at 46 pages may be it. here is another site also.
Mitsubishi Satoh Manuals
   / Mitsubishi or Satoh ? #27
Awesome and again thanx! Have a different question as I have been searching Google and here. It came with a 6' snow plow blade and has a hydrolic hose. I found where the PO had where it connects on the back in front of the seat. I built the mount for it, have it attached and plugged in the hose and basically I can feel it move a 1/16th of and inch but no up and down. Do I need to bleed that line or ??? I know, another good question,,lol. Another reason I am wanting the books so I don't feel as dumb on this thing.
   / Mitsubishi or Satoh ? #28
The line should displace any air during normal operation so bleeding shuold not be needed.
Not familiar with the operation of a snow plow blade, We don't get much of that down here.
Are you refurring to the 3 pt hitch not going up or down? That may be a filter issue or pump which is moounted on the front of the engine
   / Mitsubishi or Satoh ? #29
Its not the 3pt, that works as it should. The plow has a single cylinder and a single line and works with the 3pt system. There is an added valve off the front left side of the reservoir area just under the seat, opposite of the main 3pt control. There is a control knob in the middle that you can turn from far left to far right that effects something with the hydros. I have a very basic idea how this works and pretty sure the ram is ok as well as the line. LOL on you getting snow by the way as lived in Georgia and they don't either. Plow will come in handy though to move gravel from in front and am having to wait to get a drag blade,,,,,$$$.
   / Mitsubishi or Satoh ? #30
Also, looked at the 4 pages of PDF you sent and can't determine where to check the hydro fluid and when its full? Or if it needs some,,,level. Also appreciate all your time on all this. I can also take a couple pics of what I am talking about if that would help help me better. Just let me know.
2015 Toyota Prius (A53424)
2015 Toyota Prius...
40ft Sea Container (A52384)
40ft Sea Container...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
2025 IR IRE20 Mini Excavator (A52377)
2025 IR IRE20 Mini...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
