Mitsubushi Gray Market Questions
   / Mitsubushi Gray Market Questions #11
Thanks! I figured I would start with the filter and cross my fingers that the pump is ok. I assume the pump is inside the fuel tank making it an expensive repair/replace.
   / Mitsubushi Gray Market Questions #12
No, the pump is mounted on the engine. You follow the fuel line from the filter/shutoff valve to the pump. The pump will have high pressure steel lines, one to each cylinder. The internals have machined parts with very close tolerances are repairable only by pros.
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
