mixing concrete - or not?
   / mixing concrete - or not? #11
...but the most important thing is to build up the mix along the post and angle it down and away.
I agree here. Crowning the concrete will greatly increase the life of the post. I prefer wet set, just because I am an engineer and that produces a stronger result. But then, I also buy about 1 bag of Portland cement for every 10-12 bags of fence post mix and add a heaping garden trowel of pure cement to the concrete while I am mixing it.
I have seen the no-mix method done & it is "good enough" for most purposes. Certainly better than just back-filling with dirt.
If you decide to go that way, crown the concrete (you can still go back & crown the first set, by the way--just add more mixed cement over the top of what you have), and mix the cement for the corner posts and ones that will hold a gate.
   / mixing concrete - or not? #12
With all we have seen Harv do on here with concrete, can anyone truly not go along with every word he says. If he told me to stand on my hands while mixing it, I would believe him.
   / mixing concrete - or not? #13
Concrete won't dry the right way if you put it in dry. Concrete cures properly with exothermic action when water is added in the right quantity.
Take the time to do it right and you'll have a better concious over a job well done. Plus if you have cattle or horses banging into them, they'll last longer.
If your posts are wood, dunk the azz-end of 'em in a barrel of wood preservative for a while, then bury 'em.
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2022 Ford F-250 XL...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2012 PETERBILT 388 (A50854)
2012 PETERBILT 388...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
