Mixing different weights of oil
   / Mixing different weights of oil #11
Why not use 5w40 all year round? Even 5wxx is heavier at startup than at operating temperature. 0w40 would be even better year round and would STILL be heavier at startup than at operating temperature.
Ralph
   / Mixing different weights of oil #12
Mixing different oils isn't suggested even if it's the same manufacturers oil. Different viscosity oils even from the same manufacturer and "brand" can have different additive packages. When you start mixing already blended oils your throwing out millions of dollars of research that go into blending and testing specefic oil blends. Mixing base stocks and mixing final finished blends is completly different. If your mixing base stocks here's a handy calculation tool Viscosity Index Calculation page
   / Mixing different weights of oil #13
I searched the posts, and found little bits of help, I wont mix weights for engine applications, but I should be able to mix 10w30 x 15w40 just this once for the hydraulic system, (not HS). I got some Bio stuff to replace all but I dont want to drain till I get to the shop and the hours wont be due for a month.
   / Mixing different weights of oil #14
I have mixed so many different oils it ain't funny. One time I mixed straight 20w with 5w30 and a qt of 10w40. Don't matter but it was an old 70 Nova.
   / Mixing different weights of oil #15
Well my truck holds 40 guarts (cummins M11 in a Volvo 610). As far as mixing, I'd say that as long as you mix to high quality oils then you should end up with a high quality oil....makes sense doesn't it? I normaly don't mix oils because I usually try to make sure I have spare oil around for all of my equipment. I have however been in situations in the past where I have mixed brands and weights and I have personally not noticed any ill affects to my equipment. I would personally not be afraid to do it again if need be. That's just me though, others will disagree I'm sure :p
Troy
   / Mixing different weights of oil #16
I just changed the oil in my p/u and found that one quart of the yellow quarts was not the same as the rest. I figure it will just thin the rest out a little, but since I use a heavier oil than recommended, it probably won't hurt.
David from jax
   / Mixing different weights of oil #17
This topis is discussed quite a bit on the Bob is The Oil Guy website. They seem to say it is ok. There is a ton of reading over there.
Welcome
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
