Mixing synthetic brands
   / Mixing synthetic brands #11
Mixing brands only servers to weaken the additive package, it will not improve anything. Will it hurt anything, NO but you should only mix brands as a last resort.
Its sort of like mixing two brands of beer, its does not taste any better but you will still get a buzz.
   / Mixing synthetic brands #12
Will it hurt anything ?? probably not. Will you gain anything by doing it ? probably not Would I do it ? only if I had no other choice
   / Mixing synthetic brands #13
Synthetic oils are not all the same. Before I became an oil and grease tech with my company I thought that all grease and oils were the same as long as they had the same numbers, ect. However through eudcation I now know better, there are some synthetics that will not mix with others and when the right mix is made big trouble awaits. I agree if I needed a quart to get home I would add to the oil in the motor, but would drain it and change asap.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Polaris ATV (A50324)
378812 (A51573)
378812 (A51573)
12' CONTAINER (A51248)
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
