?@*#!!! MMM is now loose from the PTO!
   / ?@*#!!! MMM is now loose from the PTO! #1
msm50
Okay! I feel like Wonder Woman! I got the mid PTO loose from the MMM. Now for the next question: How do I get the #@$%!!! MMM out from under the tractor? I've got a 7500 HSD if that helps. It has a FEL. Thanks!!
   / ?@*#!!! MMM is now loose from the PTO! #2
Way back when I had my first tractor the owner's manual said to simply drive over it with the front tires. Before reading the manual I used the FEL to life the front end of the tractor off the ground so I could slide the MMM to the side...but running over it was a whole lot faster and easier.
Pete
   / ?@*#!!! MMM is now loose from the PTO! #3
I also think that right now, running over it would make you feel alot better /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
What would make it even better, if the MMM would make a ###&! while your running it over /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / ?@*#!!! MMM is now loose from the PTO! #4
If you have a FEL raise the front wheels off the ground with the bucket. Then pull the MMM out from under the tractor. If you do not have a FEL use a floor jack to raise front axle up high enough to get mower out from under tractor.
   / ?@*#!!! MMM is now loose from the PTO! #5
I've had several Kubotas with MMM's over the years, and all of the manuals said to simply back the tractor across the mowing deck.
Of course, it helps a LOT if the tractor has 4WD, plus I put some scraps of 2x6 in front of the MMM to act as a step up. But the mowing deck is plenty strong enough to support the weight of the tractor.
Tom.
   / ?@*#!!! MMM is now loose from the PTO! #6
I would think your MMM would be similar to the BX deck, on it you just turn the four antiscalp wheels 90 degrees and the deck rolls right out from under the tractor.
Yep! Running over that sucker tomorrow as soon as I get up. Going to enjoy it, too! May run back over it just to enjoy it more.
Black Steel Diamond Plate (A55758)
Black Steel...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
