Modified Bark Buster Log Splitter
   / Modified Bark Buster Log Splitter #1
Champy
Indiana
John Deere 990
I modified my Bark Buster log splitter by adding a steel plate / table to make it easier to use (and hopefully safer too)....kinda like the Hycrack models in the UK. Smaller pieces still want to spin, but the really big logs split nicely.
Hopefully this video shows up ok.
Bark Buster Log Splitter - YouTube
   / Modified Bark Buster Log Splitter #2
Looked at your video, and then saw this one:
Bark Buster Log Wood Splitter 3 Point PTO Screw Type Operation - YouTube
I have a Bark Buster, think it's a good machine. People say how dangerous they are - when I see the other fella's video, and a few things in yours, I see now why they say that.
Hand should never go where you put your hand. Since you are splitting with the short side of the wood on the table, it's gonna spin pretty often. You never put your hand on the side of the wood that will turn down. Never. Never ever. That's goona whack a finger off when your hand goes with. Also it will be real easy for a chunk of wood to auger in tight at the botton between screw & table. Don't grab a piece of wood there with your hand below the wood.
In the other fella's video I posted, he does many things wrong. You need to start the wood on the left side of the wood, so plenty is sliding on the pipe. Lots of overhang over the pipe Not in the middle of the wood. It's very likely to slip off the pipe and bust you to pieces. As well, it puts tremendous pressure on the splitter, trying to bust the wood from the middle - start on an end & it will split easier.
And you don't kick your foot into the middle of the block of wood - right over the point. You don't force yourself right over the point, as well as kicking puts you off balance... sheez.
Man oh man. I see now why people say they are dangerous. They sure are when used that way!
Don't mean to be all negative on you - thanks for the posting and video. Don't want to beat up on you. Most of my comments are on the other video, where they are proud of the safety string they have. See how fast it pulls wood in, see how fast it spins wood around? String ain't really gonna do much.....
Proper technique, know where your hands and feet go, keep yourself out of the zone..... Don't force things, let the machine do the work, no need to ever kick anything. When it jams up, you don't whack at the machine while it's running with the sharp side of the axe.... The simple stuff, ya know?
--->Paul
   / Modified Bark Buster Log Splitter #3
I wouldn't use one. Enough can go bad using a regular log splitter. The bark Buster looks about 600% more dangerous than a conventional splitter. Be careful out there...
I too have watched that other online videos and it is scary... which is why I tried to modifiy mine to add the steel table. I'm also only running the tractor at idle versus rated speed - plenty of torque for my needs. Now watching my video again I can also see points where I need to be more careful too (maybe everyone should video themselves for feedback). Like the strings from my hooded jacket hanging down as I bend over... never noticed that before and that would not be a fun experience if the screw grabbed them!
One further modification I'm planning on is to weld a splitting wedge onto the table right below the screw cone. This should help to split the wood plus keep pieces from wedging between the screw and table. Trying to get closer to the Hycrack version like this one...
Log splitter powered by Tractor PTO (3 point PTO) video of log splitting in action.
   / Modified Bark Buster Log Splitter #5
Just was looking at Hycrack's website.
What, is this guy the UK's Uncle Sam or something??? :laughing:
Simpson 3400 PSI Pressure Washer (A44391)
Simpson 3400 PSI...
25003 (A45336)
25003 (A45336)
2011 Ford F-250 Pickup Truck (A44572)
2011 Ford F-250...
2019 JCB 457 ZX T4F Wheel Loader (A45336)
2019 JCB 457 ZX...
2012 Dodge Charger Sedan (A44572)
2012 Dodge Charger...
2021 Dodge Ram 1500 BigHorn 5.7L V8 Gasoline HEMI Engine Automatic Transmission 158,451 Miles (A46877)
2021 Dodge Ram...
