moldboard plowing 4530
   / moldboard plowing 4530
I had to have ROPS on my L3560 sectioned 4" before tractor would pass beneath 82" garage door with ROPS folded.
A good welding shop can cut/weld so it is unobtrusive. Charged me $200; I was expecting $400.
It is hard to find accurate heights for folded ROPS; especially with redesigns that have occurred with imposition of Tier IV requirements. (Kubota L3560 spec was inaccurate.)
I would take a tape to Mahindra dealer and measure.
ENLIGHTEN US ON CONDITION OF THE PLOW. A PICTURE WOULD BE GOOD.
HOW DEEP IS YOUR TOPSOIL LAYER?
Condition of the plow is good my hunting farm is 270 miles away and I don't have any pictures. I have good heavy black dirt with very few rocks and there is mostly clay about 1' down
You never said, does the Mahindra have a FEL? If so you probably don't need to load the fronts....as the FEL will add about 1000 or 1200 lbs to the front half...BobG in VA....PS: you'd be crazy not to have the FEL...just my 2 cents. ..
It will have a front end loader as I will need to be able to load round bales.
   / moldboard plowing 4530 #13
I would not plow 8"- 9" deep with clay subsoil 'about' 1' down.
You do not want to surface clay.
Those conditions are likely to create PLOW PAN after 5-8 passes with a 3/16" plow and a 7,500 pound tractor-loader combination passing over clay.
I would find a 3/12" moldboard plow for those conditions.
I prepare food plots with a Monroe Tufline 18/20" / 915 pound mounted Tandem Disc Harrow, hand sow, then roll in seed with an Cultipacker.
http://www.tractorbynet.com/forums/attachments/332493-tandem-lift-disc-harow-monroe.html?highlight=
Well the dealer I'm working with has a 2013 6530 with front end loader that he is really dealing on. I will be looking at it on Sunday and this should handle my 3/16 plow with no problem.
   / moldboard plowing 4530 #15
Are you gonna be trailering this tractor back and forth (ie. 270 miles)? The 6530 will be a load to haul unless you have a semi with a lowboy trailer somewhere (halfway joking about the semi, but the 6530 weighs a 'bunch' more than the other one)...BobG in Va
No I just have to get it there.
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
