Montana 3940HST
   / Montana 3940HST #11
I found the same problem with the 3940 being small. Anyone know, if you move into the utility models, how much does the price go up?
I too and almost 6'4"!
Bob
   / Montana 3940HST #12
The 4340 is the smallest of the utility tractors that is far larger, much bigger loader, is a 16x16 shuttle and cost more.
At 6'4" you would be very comfortable on a 4340 utility tractor.
Thanks,
Maka
   / Montana 3940HST #13
You could consider demoing a Bobcat Toolcat C series. It is designed to lift 2000# to 60 inches, and may be able to lift 2400# to 4', that's why I'm recommending a demo - you can see for yourself if it does what you need it to do! It has a 2 speed hydrostatic drive and is a manageable size. It excels at general yard work as well as snow removal with front mounted attachments and a 2000# dump bed. If cost is a factor, consider a 46 HP model, no cab model. Good luck in your search!
Steve
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2018 Toro Sand Pro Bunker Rake (A49461)
2018 Toro Sand Pro...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
