Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,998
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
The OP is speaking of only 5 acres of land. Most TBN advise is for BIG HIGH HP tractors even if the user only has an acre of land which might not hurt a thing if money is of no object. If so, buy 2 or 3 tractors of various sizes so you will have one for each task.
However if like most folks and money IS the most important object, then a 25 HP tractor and some time would till that acreage up easily, handle a small spray rig and 4 foot shredder /disk/ tiller easily to task all the acreage he has. My Dad farmed 40 acres of flatland with an 8N Ford (19HP) so I know high HP is not needed even though it may be wanted by many but it isn't practical to get large tractors for small acreage.
I don't think he is going to be pulling a gondola loaded with 30K pound of grapes either with only 5 acres of vines so he doesn't need a 6000+ pound tractor. Get a smaller trailer and make more trips at harvest time. Also get a smaller plow that fits his smaller tractor. From the photo, he isn't going to be going up and down a hill either, horizontal across the hill just like the mowing was done so very little hill climbing during normal work.
Since he needs small track for the tractor for his grapes, I think one with fully adjustable wheels is what is needed more so than bigger engines and heavy weight although a little weight is a good thing for a tractor. Some of the CUTs don't have any ability to move the tires in and out, so make sure what you buy has that capability.
From the photo, the hills don't look that steep either so stability shouldn't be an issue. Once planted, the grapevine rows should end up making a natural contour so between the vines will end up being almost level during most of the tractor activities.
Remember, the larger the tractor, the more expensive the implements are that fit it.
PS. I don't farm grapes so my thoughts are in general terms of what is required for normal row crop farming practices.
