herbenus
This is an interesting thread. I'm tempted to let the fluid out of my tires and build a ballast box. I did a crude force model and it showed I'd need 6000 pounds, 3 feet from rear tires, to lift front axle. It's only at this that front axle load goes to zero. Now you guys can get out your tape measures and if you know where your CG is, you can get a better number. But this tells me I'll need a lot of ballast to really have much affect. And of course, we don't want front axle forces to go to zero...
Having said all this, I still believe there is a benefit in using ballast box, or implement, as opposed to fluid in tires.
Since I'm rambling anyway, imagine you load up loader with enough rocks, or hydraulic force, to lift rear. Then yes, all weight is on front. Now add enough ballast in box to just bring rear back down. At that point, all load is still on front. You then have to add a bunch more to decrease front axle significantly, by pivoting on rear. I know this was all already stated earlier. Just a different visual.
I think I will get out my tape measure and plug some real numbers into model. I think the CG is given in my manual. If not maybe someone can tell me where to find this.
Of course as someone stated, just make more trips instead of maxing out load and beyond.
