More Oliver 3 bottom plow adventures
   / More Oliver 3 bottom plow adventures #1
allen in texas
Platinum Member
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
Well I've been playing with the plow on and off for a few days when I have time and it's not bitterly cold. I am having a problem with the left bottoms not pulling true behind the tractor and I am having to steer into the furrow wall to keep the plow from pulling the tractor off track. The right bottoms pull beautifully. The problem is the fact that the landslides are worn out and the left one is actually bent. I was able to get new landslides, left and right and front and rears with wear pads and new heels just 30 miles from my home. A farmers coop ordered parts for another customers plow and the got the wrong stuff. Turns out the incorrect order was the perfect stuff for my plow and I just happened to stumble on to the parts while I was looking for something else.
I guess this weekend will be spent putting on new parts.
Now all I need are new shins and shares and I will be good to go. :D
   / More Oliver 3 bottom plow adventures #2
With luck like that you should buy a lottery ticket.
   / More Oliver 3 bottom plow adventures #3
SHOW ME THE FURROW before you count your chickens.
Good Luck.
jeff9366
Hays LT1 Tender (A61307)
Hays LT1 Tender...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2017 John Deere 6120E (A53317)
2017 John Deere...
iDrive TDS-2010H...
2022 John Deere 5055E (A60462)
2022 John Deere...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
