>> MORSE TAPER DRILL PRESS CHUCK ??
   / >> MORSE TAPER DRILL PRESS CHUCK ??
>>> UPDATE <<<
A few nights ago, my drill-press chuck finally really messed up, with one of the fingers falling way below the rest and staying there.
As I hadn't gotten around to ordering a replacement, I tried one of the HF 1/2" lathe chucks for fit.
I peeped through the knocker-outer hole and saw that there was a sufficient amount of the shank exposed to knock it out later when I get a better one.
So, I went ahead and seated it in the socket.
The first thing I had to drill was four inch holes through the "clevis" pieces for the pusher/puller pole I built (which will also serve as the boom for my boom-pole and the spreader for my twin trailing mower project, sort of a multi-use pole).{a pusher/puller pole is simply a pole with "wagon tongue" style clevis/pin-hitches at both ends; it can be used in place of a chain when towing another truck, thus no slack-jerking action; or, it can PUSH a dead truck up the ramps and onto a flat-bed gooseneck, something I have as yet been unable to accomplish with a log-chain}
I chucked in a 3/16 bit and drilled the pilot holes; then, I chucked in my HF "Silver and Demming" 1/2" shanked 1-inch bit and went to work.
Even with several of those "grab it and sling it" episodes that you always get when a large bit is almost through, the little seven-dollar chuck performed flawlessly.
I admit I had my doubts, especially since it is about one-quarter the size of the other one.
There are several swap-meets coming up, so maybe I will find a genuine Jacobs for a couple bucks.:cool:
>>> UPDATE : <<<
Although my $6.99 H-F MT-2 chuck has so far stood up to the task flawlessly, with nary a slip, and, once the bit is loosened the least, it can still be run smoothly in and out with light finger pressure alone, I didn't know just when the party might crash.
So, at a recent swap-meet, I bought a brand-new 1/32-5/8 MT-2 JT-3 KEYLESS chuck.
This guy is always at the swap-meets and has sold these same chucks for years, always keyless.
"HARVEST" brand; $65.
This thing is awesome, very heavy duty, precision.
The tapers are so precise that when I slid the chuck onto the JT-3 shank, it instantly took hold and stayed; same for the MT-2 portion when I slid it into the press; it instantly grabbed firmly and stayed there, rock solid.
I admit I was very hesitant about a keyless chuck; but, this thing is A-OKAY.
It firmly grips the bit with the lightest amount of finger pressure on the knurled rings and releases so easily it is un-believable, yet holds the bit more firmly than any keyed chuck I have ever used.
So far, so good.:cool:
   / >> MORSE TAPER DRILL PRESS CHUCK ?? #23
A top of the line Jacobs 16N ball bearing super chuck which can open to 0.630 will last forever and will not slip. A new one is pretty pricey. But a used on in great shape can be had for under $90 or so on eBay.
Agreed...except, I will add that if you watch the Enco sales and/or promotions you can usually pick one up for a hair over $90 I know my 14N ended up costing me right around 100.00 brand new, shipped to my door.... I love that chuck, I've drilled holes of all sizes, materials, etc and it has never failed to impress me. I personally fail to see the need for a chuck larger then 1/2" because any bit larger then 1/2" is available with a 1/2" Shank...
My dad picked up a used 16N and we rebuilt it at home...rebuild kits end up costing a bit..Not cheap, but at the same time, not hard to rebuild a chuck.
   / >> MORSE TAPER DRILL PRESS CHUCK ?? #24
All the keyless chucks I've used have been Albrecht, but any good keyless should be fine. Love em BTW. :)
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
John Deere 5100M (A53317)
John Deere 5100M...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A55973)
Miller and Smith...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
