motor locked up
   / motor locked up #1
johniebomb
green ridge mo.
175 Allis gas
Not very good at the search function, I have a international 2424 that was a airplane toter. It ran a couple of years ago but now when I went to work on it the motor is locked up tight. Is there a process everybody uses to un stick one? Help please, thanks for reading my post.
   / motor locked up #2
Check the fluids in the crankcase to see if there is to much fluid causing a hyd lock. Oil, water, gas or diesel, whatever.
If so, drain and refill to correct level.
   / motor locked up #3
I have heard of people using a mix of ATF and kerosene to free a stuck engine.
   / motor locked up #4
ATF and Acetone is the best.
   / motor locked up #5
Sounds like the pistons are seized from sitting too long.
Pour something in the cylinders as suggested,( remove plugs for gas and glow plugs or injectors for diesel). Let er sit for a few days and try it again.
   / motor locked up #7
Don't keep trying to move the engine on the starter.
Get a wrench on the front pulley, move it it one way and then the other.......just like you would if loosing a bolt or a nut.
Then let it rest with some more penetrating oil into the top end if needed.
Do it again the next day.
Patience is the operative word. Those rings will break free sooner or later.
   / motor locked up #8
I agree, :thumbsup: do not use the starter, unless you have a spare on hand.
   / motor locked up #9
Better yet, remove the starter and use the ring gear to pry on against the starter opening in the block. Best leverage, only small motions, and no breaking crank bolts.
Jim
   / motor locked up #10
You can also hook on to it and drag it to try and bust it loose.
   / motor locked up #11
This is the best easiest option and if this don't work then nothing else will .
Sent from my iPhone 5 using TractorByNet
   / motor locked up #12
Jim
I've never done that with a tractor engine, but I can understand what you're saying. :)
Years ago, when I was working for the railroad, we would sometimes get a locomotive in that wouldn't crank because the starter would be hung up on a bad tooth on the flywheel. We would do as you said and take the starter off and use a bar to rotate the flywheel a few inches so the starter would catch a good tooth. Then we put the starter back on and cranked it up.
Of course the engine wasn't seized, but you could turn that big whopping diesel over a little at a time with a fair amount of ease.
As long as you can get a bite on the flywheel, that would be the best area for leverage IMO.
:twocents:
   / motor locked up #13
I have seen in the past, that rods can get bent using the pull/drag method, on ones that were stuck worse than thought.
Years ago, I took an old spark plug, removed the porcelaine and electrode. I brazed a 3/8" pipe sleeve to it, then reduced to 1/4", so as to screw in a male air hose connector. With the valve rockers loosened, or removed, connect to a portable air tank, or my small portable air compressor. This of course after filling the cylinder full of a penetrate concoction. Adding 100-125psi of air sure helped..!!
   / motor locked up #14
Sure you can pry, yank and tug. Something somewhere will give eventually.
You will be happier purchasing a gasket set.
After you take it apart and find all the rust and gunk jamming it stuck. You will be glad you cleaned it up.
Valves often stick. So now you keep heaving until a pushrods bends, a valve gets bent, a cam follower/cam lobe gets wiped. Or as previously stated a connecting rod gets bent.
   / motor locked up #15
A friend of mine freed up a stuck engine in a tractor by loading it on his trailer and chaining it loosely. After driving around in a field for a while, the chucking of the tractor back and forth in gear freed the engine. No massive strain to the crank or drive line components. Pulling the plugs, making sure the valves aren't stuck and using your favorite "Loose Juice" can't hurt either.
   / motor locked up #16
If it ran a couple years ago, and was not out in the weather... it should come free with just a mix of light oil and solvent in each cylinder several times a day for a couple days.
On level ground, with it in high gear, you can rock it back and forth by hand an often get them to break free with little strain on the internal components. Or you can put a old pto coupler on the pto stub and turn the engine by turning the stub. As others have said, just don't go after it too aggressively as you can cause more damage.
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
TANK MANIFOLD (A55745)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A60429)
2018 JOHN DEERE...
208316 (A58375)
208316 (A58375)
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
