mott 72 flail mower roller rebuild
   / mott 72 flail mower roller rebuild #1
jonsstihl
Quebec, Canada
Any one have any ideas on how to get a tie shaft out of a 6 foot roller. I managed to get the nut off the end but now the tie shaft seems to be a tight fit on the bearings and the roller is kind of big to handle. I have it soaking in 50-50 mix of diesel and atf but
I need to replace one roller bearing.
I got it off.
I used the rollers weight against itself. I threaded the nut on the end of the shaft then held the roller vertically and dropped it onto a thick steel plate I had set on the floor. That drove the other side bearing right out of the roller as well as the tie shaft. Now I need to use the same technique to get the roller bearing from the other side out of the roller since a 7 ft 1/2 inch bar used as a drift isn't working.
   / mott 72 flail mower roller rebuild #3
Sounds like you're wrestling a bear for a piece of salmon this morning. When my mott had that roller with the inside bearing (been changed) I used a slide hammer puller to get one of them out the other side fell out. That's a good design and last many years but my roller finally broke into and I had no luck welding it back together. Good luck..
Chicago Pneumatic CPS130 (A47477)
Chicago Pneumatic...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
2013 HERCULES ALUMINUM KILL TRAILER (A55745)
2013 HERCULES...
