"mound" type septic system
   / "mound" type septic system #21
Re:
CRJCaptain:
About the spray system... Like I mentioned before, everything about my spray system, from design, to cost, to maintainance, and permits is completely dictated by the local powers, so your experience may be alot different.
I've only lived with the system for 3 months, but here's what I know so far...
Our design is to gravity flow into a standard 3000 gal septic, then gravity flow into a 3000 gallon holding tank. That tank is alarmed and pumped to a pair of sand filters. The sand filters are made from the bottom halves of 3000 gal tanks. Then through a chlorinator and into another alarmed 3000 gallon holding tank. Then pumped out to be sprayed about once a day over a 1/2 acre spray field.
Count up that large number of tanks, pumps, alarms and labor, and you see why the cost is so high. And I looked over the design documents for our system, and it is EXTREMELY overengineered. The county is covering their behinds, and what do they care, it's my money... :(
These systems are relatively new, but there's probably a hundred or so installed around here. And I'm on the fringes of the suburbs, so due to lack of land, most of the remaining lots have some sort of non-conventional septic, and it appear to be becoming the most approved non-convential.
Our spray field is in a pine stand, so I need to keep the undergrowth clear, but the standing pines keep the floor covered with needles, so erosion is not a problem. We are absolutely NOT allowed to irrigate with it.
I was told by a nieghbor that the only smell can come from the sand filters, and only when the pump is running. So I had the sand filters located as far away as I could physically do it, about 300 feet from the house. I've yet to notice a smell, maybe because its so far away?
The chlorine kills any smell after that. The "approved" chlorine tablets do not last long, and are expensive also. However the inspector told me go ahead and use pool chlorine tabs, so next time I run out, I'll try that.
Our inspector wields the ultimate septic tank authority, and can make your lot worthless in a second, so play by his rules. A good conversation with the inspector and neighbors may help you out alot.
Overall, I suspect it will work out OK. Some neighbors have had them for 5 yrs or so with no problems. And after the sticker shock wears off, I'd rather have this than a poorly designed system that save a few dollars.
Mike
   / "mound" type septic system #22
Re: \"mound\" type septic system
As an update...I was speaking with a person who reports to me who is out recovering from back surgery. As if she didn't have enough problems, the pump in their sand mound quit last week. It lasted only 12 years.
   / "mound" type septic system #23
Re:
That was a comment from my builder - The 2900 lbs does not include the MMM or the 430 loader. At the last house I had to have the lines blown out due to plugging. I'll probably use the 4310 after a couple years - I'll drive fast.
<font color="orange">I'm looking to purchase some property </font> After making two bids on the property the sellers started to play games and now want the full price of the property. Both my builder and agent said the property wasn't worth the asking price. Soooo still looking for ground. Thanks to everyone for their helpful comments and especially cwave for the photos. Stanley
   / "mound" type septic system #25
We use lagoons here in Kansaw. They work OK but like the sand mound they are ugly and use up valuable space. I know there are some new systems that can be used in heavy clay soils that use aerator pumps and aerobic bacteria. My neighbor was quoted 15,000 dollars for one so he is going with a lagoon instead which are about 5,000. My house uses a septic tank as a collector and then I have a pump in that which pumps to a lagoon. Yep, the pump failed after 4 years. The new pump is much heavier duty. Actually, the first pump failed due to arcing across badly installed wiring. Good luck, I understand your dismay at having a huge sewage treatmant plant in your backyard. J
   / "mound" type septic system #26
Re:
Came across my first Mound septci just today. Designed for a new project in the Torres Strait Islands north of Australia.
They call it a "Wisconsin Mound" so some of you may know why that is?
I think it is used in this application to prevent contamination of groundwater which is affected by tidal influences.
Cheers
   / "mound" type septic system #27
Re:
"Wisconsin Mound System" is the term I've heard used here but I don't know the story behind it.
Re:
What did your mound system cost?
   / "mound" type septic system #29
</font><font color="blue" class="small">( I'm looking to purchase some property and I noticed on the listing that the property requires a "mound" type septic system. I gather that a perk test most likely failed. I've lived in two homes that have "normal" below grade septic systems but know nothing about the "mound" type. I hear they are quite expensive to install compared to the below grade system. And of course it looks like a cemetary plot in your yard. Any thoughts, good, bad, etc. concerning this type of septic system. Additionally, the property is very flat, has a small pond on it along with a small creek. Any idea on the cost to install this type of system? )</font>
Here goes:
On the side, we install "Engineered Systems" or what you refer to as a "Mound". The price of the installed system will be based on the number of rooms in the house that require a sanitary hookup as well as the number of occupants. In Michigan, prices will range from about $7,000.00 to around $25,000.00, depending on size and life expectancy.
Life expectancy:
The system has a "life". That is, it will not last forever. At sometime, the system will become "saturated" and will have to be done over again. Allow for that when designing a system and allow for extra capacity.
I'm not familiar with your locale and local laws or you state sanitary code for that matter. Retain a qualified sanitary engineer and allow him to design a system for your needs. /forums/images/graemlins/confused.gif
One important note: The surface of the system should never be planted with anything other than grass and should not be used for a playing surface or have any compaction other than natural settling of the soil.
Daryl
Forage Services, L.P.
   / "mound" type septic system #30
Re:
Sorry can't help you there. Price was included in total cost of new house.
2022 VERMEER RTX250 WALK BEHIND TRENCHER (A53843)
2022 VERMEER...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
Case Maxxum 140 (A50120)
Case Maxxum 140...
47 ft. Portable Transfer Dock (A53117)
47 ft. Portable...
2014 Chevrolet Tahoe 4x4 SUV (A52377)
2014 Chevrolet...
Life proof SPC Luxury (A53117)
Life proof SPC...
