mounted KingKutter pallet mover to FEL bucket
   / mounted KingKutter pallet mover to FEL bucket #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I came up with a fairly simple way to mount my KingKutter pallet mover to my FEL bucket. I made the bracket on top of the bucket out of 4" angle iron, then made a "toplink" out of 3" x 1/4" flat steel. I welded a piece of angle iron on the bottom of the pallet mover and drilled holes to pin it to the bottom lip of the bucket so it wouldn't slop around. It works good!
The bracket I made also makes a good place to hook up a chain.
I didn't trust trying to weld to the round part of the top of the bucket, so I used 3/4" grade 5 bolts to attach the bracket. I've tested it and it stalls the FEL when I put a lot of weight on it, so it should be strong enough for anything I can pick up.
Here it is in action.
   / mounted KingKutter pallet mover to FEL bucket #5
Bucket forks work fine for lifting, but the weakness (in my mind) in the typical clamp-on style is they aren't designed for down pressure. Yours look well suited for lifting and compacting (down pressure). I like 'em. Good work.
OkieG
   / mounted KingKutter pallet mover to FEL bucket #6
Looks great!
Just be careful with that extended reach, your rear wheels can get awfully light! /forums/images/graemlins/blush.gif
Thanks for the compliments. I'm on a roll, so I went ahead and adapted the boom pole also.
It will reach up to 17'. I'll mostly use if for lighter stuff, since it has so much leverage it will dangerously tippy.
   / mounted KingKutter pallet mover to FEL bucket #9
Pretty neat ideas. Thanks for sharing them! /forums/images/graemlins/smile.gif
   / mounted KingKutter pallet mover to FEL bucket #10
</font><font color="blue" class="small">( Pretty neat ideas. Thanks for sharing them! )</font>
I agree. Really nice adaptation. John
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Mitsubishi 24V Electric Pallet Jack (A51691)
Mitsubishi 24V...
