mounting 4" hand truck tires
   / mounting 4" hand truck tires #1
jake98
Veteran Member
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
I'm open for all suggestions, this thing's kickin my butt. I got it off and got a tube in it, but getting it back on is proving to be a pain.
   / mounting 4" hand truck tires #2
Does it have a 2-piece rim? Otherwise some soapy lubricant might do the trick.
I think I'm gonna make one out of wood on my bandsaw. It's a 4" molded rim. There must be a trick to it, no way can I get enough hands and screwdrivers on it, and I don't want to stick myself in the eye.
   / mounting 4" hand truck tires #4
Put a long bolt through the center hole and clamp down on it with a vise. Then you only have to keep it from spinning.
Aaron Z
Aaron Z
That sounds like a good idea, thanks. I was trying to do it with the h/t stood on it's side, but that would be better.
Edit: I put a threaded rod thru the drill press table and used 2 vice grips on the rim, that was the ticket. Then I just had to fight with the valve stem. Now I know why they get so much for a hand truck tire, because they can.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
Sullair 185 DPO JD 100psi Towable Air Compressor (A49461)
Sullair 185 DPO JD...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
2016 HINO 268A BOX TRUCK (A51219)
2016 HINO 268A BOX...
