Moved and need to upgrade w budget.
   / Moved and need to upgrade w budget.
Is there a company that makes landplanes that my 212 could use?
I have a 3 point manual lift pin hitch, not sure what its from though.
Not sure if my little tractor could pull one though.
There's not many farmers near me. There all on the other side of the river, an easy 30 min tractor ride.
   / Moved and need to upgrade w budget. #12
Unless you get something than the 212 I think you would be better served to hire a farmer or landscape contractor to smooth it for you. Most of the forum members simply enjoy tractors and equipment whether it is economically feasible or not.
The 4' landplane I built is about all my x749 can handle this would work better with a 2x20 series. It should be obvious that the larger landplanes with their greater span can get the ground flat easier than a smaller model. The small ones are handy for tight quarters work and under trees where the larger ones can't fit. Other than the one I built I haven't seen any from the implement companies smaller than 5' wide so far.
TRUCK FLATBED (A52472)
2013 Ford F-150 Pickup Truck, VIN # 1FTFW1EFXDFB07930 (A51572)
2013 Ford F-150...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2 JATCO CORP Transmissions (A50325)
2 JATCO CORP...
