Moving a dirt pile efficiently. Learn me something.
   / Moving a dirt pile efficiently. Learn me something. #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
I've been around tractors for 40 years I guess, but this one is the first one with a FEL. I've had some days off and I am moving a pile of topsoil for my church and spreading it out with a box blade (at which I have a lot of experience). For the most part I've just been driving straight into the pile RPMs up and start raising and curling the bucket to get a good load. The tractor is a 45 horse Kioti with the shuttle shift, so I have to clutch from forward to reverse. I guess my question is about lugging the engine down momentarily until I break free with the load. This seems almost inevitable unless I turn a 12 hour job into a 30 hour job. Does it hurt anything to do this? I've been driving into the pile in 4wd and in first or second gear in mid range. One thing I've tried is shaving the edges off the pile which creates a lot of loose stuff that is easy to scoop, but that just seems like extra work and time. What is your general methodology, gearing, speed, rpm etc?
   / Moving a dirt pile efficiently. Learn me something. #2
Do just what you are doing,,, Work that tractor,,, that's what it was made to do. You are doing it just right. If your FEL will pick it, your tractor will handle it, providing you have counter weight, but you know that any way with years of experience. BTW Box blade is one of the best counter weights you can have, and one of the most usefull implements you can have. G.
   / Moving a dirt pile efficiently. Learn me something. #3
AS long as your not stalling the motor, your doing all right. With 4wd, you don't need to ram the pile at warp speed because as you lift, your front tires get ALOT more traction. Wasting time trying to get an overflowing bucket isn't worth it either, im sure as you work your way through, you will get a feel on how to load the bucket efficiently. If the pile is really packed in tight, you can start a little higher to keep the breakout forces a lil lower while filling the bucket. Happy tractoring!
   / Moving a dirt pile efficiently. Learn me something. #4
Do you have a tooth bar on the bucket? If the pile is settled/compacted very much and you don't have a tooth bar, you might find it helpful to backdrag the pile to break it down a bit, then scoop up the looser debris. With a tooth bar, you likely wouldn't have any problem just digging right in. As long as you aren't repeatedly stalling the engine, don't worry about rpm dropping while you scoop. When I do a job like this, I find myself wishing I had the HST version of my tractor (not available on the DK45 when I bought mine in '06).
   / Moving a dirt pile efficiently. Learn me something. #5
I find that sometimes it works best to back drag from the top of a well compacted pile so you have some loose material to scoop up. Otherwise it sound like you are doing OK. Don't ram into a pile of dirt at more than a slow walk speed because you could damage the FEL.
The best way to get a full bucket is to start with the bucket cutting edge in a slightly downward from level position and then lift and tilt back as you drive into the pile. HST is really nice for this as you can keep the forward pressure on and not stall the engine, but straight gear will work too if you gear it down slow enough. Spinning the tires a bit is ok as long as you aren't digging deep holes when loading.
   / Moving a dirt pile efficiently. Learn me something. #6
Pretty much what everyone else said, I've been using a FEL since 1986 and I still have to take the time to get a full bucket, back dragging etc., so I spend about the same amount of time hauling partial buckets or taking the time to get a full bucket.
I rarely have a pile of anything loose enough to just drive in and get a full bucket consistently using the method in the manual with one easy pass.
I use HST as well as gear and when using gears, I go in fairly slow using the foot throttle for more power as needed and usually spin my tires a bit as long as I'm getting traction and making progress.
   / Moving a dirt pile efficiently. Learn me something. #7
Lots of good advice here. I'd add one more thing.
I had 550 lbs of topsoil delivered, and tried various ways of distributing it with the skid loader, tractor, etc. The fastest and easiest (on the machines and operator) way i found was to use only the box blade. These were lower piles (a few feet) though.
If you have to distribute the dirt immediately by the pile, I would break down the pile and use the box blade. If it's going "on a trip," than the loader (or a loader + trailer) will be the way to go.
The excavator that dropped off the soil (there were a few 18 yard trucks running for a while!) tried to sell me on 2 days of him on a dozer to spread and grade. It took about 3-4 hours of machine time to actually spread the dirt, and then a few more hours of final box blading and a landscape rake to be prepared for seed. This was on my old Kubota L3650.
Thanks for all the replies. The dirt is surprisingly good. I was afraid it would be our infamous gumbo we have in so many places down here, but it's not. Agree totally about moving dirt with the box blade but I'm having to go up and over a new concrete drive (where the dirt came from) and dump and spread it in a low area about 75 feet away. Yes an HST would be handy if I did this all the time. I'm headed back up there now. Will post a picture when I get it done.
   / Moving a dirt pile efficiently. Learn me something. #9
I do it the same as others have suggested. Drop the bucket over the top, dump the empty bucket, and pull the top off the pile landing in front. I can usually get a couple good buckets full, then pull more down. Even if the pile seems loose, the inside is compacted on itself, and backdragging it off the pile makes it much easier. It also seems to load the bucket easier, scraping/floating on the ground as I fill it compared to stabbing the center of the pile.
   / Moving a dirt pile efficiently. Learn me something. #10
When things appear to be going slow keep in mind how long it would take to do the job with a shovel and a wheelbarrow, and how much aspirin or Tylenol you'd have to take for days afterwards! :)
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
NEW Long Forks (A59000)
NEW Long Forks...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
