Moving a Large Shed
   / Moving a Large Shed #1
badwolf1961
Rhinelander, WI.
none
I need to learn how to move a large shed. 28 x 48 feet. It is of 2x4 construction. Trusts are also 2x4. Metal roof. I plan to move it about 70 feet. I also want to raise it about 18 inches onto a cement block foundation. How can I prepare and move this?
   / Moving a Large Shed #2
never done it, but I would suggest some diagonal bracing to prevent the shed from racking. If your new foundation isn't built yet, you may want to leave some gaps to allow any timbers that are under the shed to pass through.
   / Moving a Large Shed #3
I think I would start off with a phone call to someone that has done it a few times. I don't think this is a DIY project.
   / Moving a Large Shed #4
I agree with bigtiller, this a large building for a DIY project. Bracing and lifting this straight will be a challenge as well as any wind will want to push this around.
   / Moving a Large Shed #5
What equipment do you own, or have access to?
   / Moving a Large Shed #9
I've moved a 14 X 22 foot building but 28 x 48 isn't something I would attempt on my own ... Not without 100 men like the above videos.
   / Moving a Large Shed #10
Check with your friends on facebook and see how many would come over and help tote it. :laughing::laughing:
Actually I would really like to see how you end up doing it. I moved a 12 x 12 chicken coop and my FEL would even lift a corner of it.
If I really wanted to do it myself, I would consider bracing it good, just slide it on skids, put it in place and jack it up a little at a time all around, and put the foundation under it and let it down.
How hard can that be?
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
