moving concrete pads
   / moving concrete pads
ok got the pads home and unloaded here are the pictures.
   / moving concrete pads #12
Looks good. How did you get them the last little bit off of the stack without falling? Or did you just let them fall?
ok got a little more time to describe the events,pic 1 & 2 are at the place where I got them the guy said they are 2800#s a piece and they loaded them all at once man what an impressive fork lift they had. pic 3 was when I got home and backed in a stump hole needless to say even with four wheel drive I could not pull that load out. I went inside and got something to eat and I thought I'll call my father in law and get him to come look at how I got stuck, 3 hours later he said he'll never fall for that trick again. pic 4 is the way I had to unload them there is a metal ramp under the pad and as I pull back on the pad it slid down the ramp no problem. worked so good the first time I did it five more times. now they are on the ground as you can see in the last two pics
   / moving concrete pads #14
Nice work, and at $58.00 you sure are a winner.
Being precast and flat both sides will make installation a snap. Slide in place on prepared bed and grind off the loops and presto.
I am sure those slabs were armored as otherwise they would be in pieces. Shucks I bet you could park a loaded dump truck on those.
Piloon, after I unloaded the first one I drove on it when I unloaded the other four, so a four thousand pound backhoe and one end of a concrete pad. yes sir I think they are going to be ok. just thinking the other side is flat no loops I maybe able to flip them so the loops are to the ground.
John Deere TX Gator (A60462)
John Deere TX...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2022 John Deere Z930M (A57148)
2022 John Deere...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
2007 MACK CV713 ELITE DUMP TRUCK (A60430)
2007 MACK CV713...
1770 (A58375)
1770 (A58375)
