MadDog
Platinum Member
I have been excavating for a smallish (15x80) landscaping pond. In addition to the usual variety of rocks and small boulders that my B7800, FEL and toothbar can handle without too much trouble, I have encountered three or four simply humongous boulders.
The latest was significantly over 1 cu yd. and was so heavy that my FEL couldn't budge it, much less lift it high enough to bring it up the ramp from the 6' deep bottom of the excavation.
So....what to do?? For whatever help it may be to others, here's how I solved the problem:
First, I dug around the boulder to its base, using my Woods 7500 BH.
Second, I used the FEL to backdrag ramps on both ends from the base of the boulder.
Third, I went in on one of the ramps, positioned the FEL blade about 2/3 up the boulder and used the FEL to push the boulder over and onto the opposite ramp.
Finally, I came in on the opposite ramp (the one the boulder had been tipped onto), brought the FEL in tight to the base of the boulder and ran a 20' length of 3/8" chain several times from the bucket hooks atop the FEL around the base and lower half of the boulder. I then backed up (FWD all the way, of course), dragging the boulder up the ramp and out of the excavation. The boulder occasionally started to slip out of the chain and it was necessary to re-rig the chain several times, but removal of the boulder to the top of the excavation and some 50' from where it had been was accomplished relatively easily.
My youngest son had seen the boulder yesterday morning when it was still half buried at the bottom of the pit. When he got home from work and saw it neatly placed at the end of the boulder wall behind the soon-to-be pond, his reaction was
how the @#%$*(@# did you do that? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Who says a 30hp tractor can't do serious work? /forums/images/graemlins/shocked.gif
