Mow and then disc?
   / Mow and then disc? #1
jay3534
zebulon nc
AC 5015
I've got a pasture that due to time restraints have grown up to to about 3 feet. Now we have had a heavy frost and the grass / weeds are dying. Should I mow and then disc to cut up dead grass? Mow only? Disc only?
   / Mow and then disc? #2
You will have better results - mow first, then disk. Many would burn first, then disk. That's only if your pasture grass is dry enough and you are sure the fire can be controlled.
   / Mow and then disc? #3
Mowing only is fine if you intend to keep the pasture indolent. If you disc, zillions of dormant seeds in the 'soil seed bank' will germinate when sunlight stimulates them, giving no improvement.
If you intend to renovate the pasture, mow than disc periodically, after weed germination occurs but before weed seeds are produced. Seed or overseed the same day after discing and smoothing the ground when temperatures are appropriate for the seed you wish to dominate. Improverd seed varieties are highly productive but require fertilizer and water during dry periods to give high yields. Rolling in the seeds with a roller or cultipacker will improve germination rate of desirable seed. Most grass seeds require some direct sunlight to germinate.
   / Mow and then disc? #4
Allis Chalmers 5015 Dimension​
Allis Chalmers 5015 tractor photo
1982 - 1985
Sub-Compact Utility tractor
Hinomoto built
Allis Chalmers 5015 Weight
1387 lbs
629 kg
2WD Shipping:1278 lbs
579 kg
4WD Shipping:1448 lbs
656 kg
Wheelbase:50.8 inches
129 cm
Length:82.7 inches
210 cm
Width:40.9 inches
103 cm
Height (steering wheel):46.9 inches
119 cm
Height (hood):40.9 inches
103 cm
Clearance (front axle):13.7 inches
34 cm
Clearance (rear axle):14.2 inches
36 cm
   / Mow and then disc? #5
You can attempt to disc wirth a subcompact tractor but I doubt pan penetration will exceed 2" with the disc weight a 4-WD subcompact tractor can pull. Most perennial weeds and brush have roots deeper than 2" and will survive. A 2-WD subcompact tractor will have less disc pulling capacity than a 4-WD subcompact tractor.
Disc moist soil for optimum pan penetration.
A single bottom 12" size moldboard plow will likely penetrate 5" to 6" but it may be tricky finding a used turning plow that will fit the Three Point Hitch on your subcompact tractor. New plows for subcompact tractors are available from everythingattachements.com in North Carolina for $860 delivered.
LINK: https://www.everythingattachments.com/EA-Subcompact-Tractor-12-Plow-p/eta-12-subcmpplow.htm
I see in your tractor specs that UNUSUALLY your subcompact tractor has ground clearance of 14". A single bottom 12" plow for a compact tractor MAY fit OK. The unusually tall wheels on your subcompact tractor reduce pulling ability somewhat.
   / Mow and then disc? #6
I wish I had a heavier disk - but I don't. Land Pride - DH1048. If I plan ahead - just as things start to firm up - in the spring. Put my 400# concrete cube on the disk and go slowly. Otherwise - a waste of time and fuel.
I've turned the soil - later in the year. First with my Pittsburg single bottom moldboard plow - then the weighted disk.
   / Mow and then disc? #7
One thing you can be sure of when asking advice on TBN is an abundance whether it fit's the circumstance or not. If you will take time to say A. What you want from the land as in hay,grazing,wildlife cover or whatever B. What kind of plants are present (desiriable and undesirable) C. Whether max production or minimal maintenance is primary importance,I believe you will get better advice.
   / Mow and then disc? #8
Just want to "cut up the grass?" Mow only and let it lay.
Can't burn as I always have breeze. Good reminder on dormant seeds. I'll just mow.
Thanks for the replies
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
2018 Yamaha Waverunner Jet Ski (A59231)
2018 Yamaha...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
Deere 335P (A53317)
Deere 335P (A53317)
