johnrex62
Platinum Member
Got out to check things out and found the gearbox is full of grease rather than oil. It is a beautiful clear purple color at the check hole. What is the best way to get the grease out, since it doesnt flow like oil?
Why didn't you place it on highrt ground in the first place?This morning I discovered my rotary mower was at the bottom of a newly formed river. We got nearly 7 inches of rain in a couple hours and have flash flooding at levels not seen by anyone in the last 50-100 years. As luck would have it, I was using my rake last and the mower was off my tractor overnight for the first time in two years. Anything to be overly worried about? I have not been able to inspect it yet, what should I expect to find?This is what I saw at 9am. The ripple in the surface about 3/4 of the way to the left edge, in front of the small stand of tall weeds inbetween the trees, is about where the mower sits. View attachment 272849This is how it looked 3 hours later.View attachment 272850It is on "dry" land now, but I am not sure how much, if any, water penetrated the gearbox.![]()
open drain.. pressureinze fill blow out what you can.. then pressure wash it a bit.. then pour in some alcohol, and diesel and atf fluid.. spin her up for 15-20 seconds low speed.. then drain that out and refill.
tip.. if someone had 0 or 00 ep grease in it.. then it may mean the input or oupput seals weep or leak. filling with 0 ep or 00 ep was a common fix... some mowers even CALL for 00ep grease. I have a howse that specs it..
if the seals are good.. go 85/140 or synthetic gear oil. if they weep.. and you will know with the alcohol / diesel / atf mix.. then go with 00 ep grease... snapper dealers sell it.. stens lube products do too..
most boxes that are greased are leakers. thus with normal use, some grease slowly leaks out and you add a few pumps a year.
as long as it doens't get water in it.. no need to actually trade it out.
soundguy
